Removing Wing How To Pt 2
Old Mar 5, 2002 | 09:16 PM
Chris_R's Avatar
Default Removing Wing How To Pt 2
Ok, I did a search and came up with this post, but it was archived so I couldnt reply. After reading the quote below my questions are about the double sided foam. I assume its got adhesive on both sides if you need to use floss to get it loose? Which leads me to my next question. When putting the wing back on do I just use the existing foam or do I need new foam?
"after you remove the bolts there is also this strong double sides foam which is best taken off with dental floss... If you don't have anything to cover the holes and there is a chance of rain, you could always cover them with tape! A friend did that and it worked well until he got some plugs for them, which can be found at Kragen."
[Modified by OutkastLV, 2:18 PM 3/6/2002]
Old Mar 5, 2002 | 09:21 PM
Rob :190:'s Avatar
Default Re: Removing Wing How To Pt 2 (OutkastLV)
since i frequently change my mind about winged-wingless, i got some rubber gasket material, cut it in the shape of the bottom of the wing, and use that. easy and quick. without plugs though, its not a big deal, the water wont get into anything or harm stuff.
Old Mar 5, 2002 | 09:24 PM
Chris_R's Avatar
Default Re: Removing Wing How To Pt 2 (Rob1035)
Yeah, I'm not worried about the water because Ive seen where it drains to if it getn in the holes. I was just wondering if the Foam or whatever is reusable or what not. Thanks!
Old Mar 5, 2002 | 09:28 PM
TypeR 599's Avatar
when taking off the foam, will there be permanent tape marks from the tape foam in the shape of the bottom of the wing?
Old Mar 5, 2002 | 09:30 PM
Rob :190:'s Avatar
Default Re: Removing Wing How To Pt 2 (TypeR 599)
no, try some goo-gone, or similar, then some rubbing compound
Old Mar 5, 2002 | 09:44 PM
TypeR 599's Avatar
so that wing is not held on by some sort of cement glue...hm..good to know . Say if i take the wing off and take off all the excess glue stuck to the hatch and wing, when i put it back on, will not having the glue there hurt the paint or anything else?
Old Mar 5, 2002 | 09:50 PM
Rob :190:'s Avatar
the wing is definately glued on, but use some fishing line to cut the glue, pull off the wing, clean the glue from the decklid and wing, then fashion some type of seal for when you want to put the wing back on. my paint is fine, and i've removed, replaced the wing multiple times.
Old Mar 5, 2002 | 09:56 PM
TypeR 599's Avatar
so do you have to have the glue there when putting it back on? so should we preserve the glue/tape on the wing after taking it off?
*sorry for all the questions
Old Mar 5, 2002 | 10:03 PM
Rob :190:'s Avatar
I dont reglue it, just use the bolts, havent had any problems with the wing falling off or what not.
Old Mar 5, 2002 | 10:07 PM
TypeR 599's Avatar
cool, thanks for all the help Rob1035 .
one more question , can you hear the wing vibrate against the hatch since there is no cushion between the wing and the hatch now that the glue is gone?
Old Mar 5, 2002 | 10:11 PM
itr501's Avatar
when the bodyshop took off my wing to paint my hatch they didnt bother putting back on the glue/tape. Kinda bothers me but hey what are you gonna do about it.
Anyone got the torque specs on these bolts?
Old Mar 5, 2002 | 10:16 PM
Rob :190:'s Avatar
no, i've got that gasket **** in there, its tight and doesnt rattle. As for torque specs, i dont know, but the wing is light as hell so it shouldnt take much pressure
The Droogan Leader
Oct 16, 2006 06:52 AM
GetAwayDriver
Oct 14, 2004 02:46 PM
speedevo
May 18, 2003 10:09 AM
Phoenix_ITR
Dec 5, 2002 07:53 PM
IGGY
Jan 26, 2002 03:00 PM
