burning oil???
i put a gsr in my eg coupe about a month ago and it was buring some oil. i could see it when i get on it and smell it too. i relpaced the valve seals and it still does it but worse. if i drive it and stop at a light then go normal ill leave a blue cloud at the light. is it the rings? did leak down test everything seemd good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95JAPGSR »</TD></TR><TR><TD CLASS="quote">i put a gsr in my eg coupe about a month ago and it was buring some oil. i could see it when i get on it and smell it too. i relpaced the valve seals and it still does it but worse. if i drive it and stop at a light then go normal ill leave a blue cloud at the light. is it the rings? did leak down test everything seemd good.</TD></TR></TABLE>
you did the leakdown wrong. if you have a cloud of blue smoke and couldnt find a problem with the leakdown test you/the tester are wrong.
what were your leakdown numbers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrdx »</TD></TR><TR><TD CLASS="quote">You should probally do a compression test to check you rings</TD></TR></TABLE>
wrong!. If you have a bad oil control ring how does that show up on a compression test since all your compression rings are still good. I am betting the leakdown test was done wrong. and from personal experience I bet its the oil rings. My motor is going through the same thing right now with my gsr. compression was 190/190/180/190 and dyno'ed 156.4whp, and i burn oil exactly like the poster mentions.
jetlude
Dec 2, 2007 03:40 PM
Spence
40
Mar 12, 2007 09:51 PM
