95 Accord ignition
Old Oct 16, 2005 | 07:30 PM
floriudabrain's Avatar
Default 95 Accord ignition
I have to replace my ignition,(95-lx, auto) switch is bad, key gets stuck half the time, doesn't turn half the time, stops half way etc.... I received the new factory replacement part, looks pretty straight forward to put in. I was wondering if there are any hidden secrets I should know about or hang ups I could anticipate? Thanks in advance for your input .
Old Oct 16, 2005 | 07:34 PM
gianinline's Avatar
I don't think that there are any secrets, but you may have your battery disconnected while doing the work just in case!
Old Oct 16, 2005 | 08:23 PM
HondaTechPro's Avatar
Default Re: 95 Accord ignition (floriudabrain)
Yeah it is pretty easy to install. No real secrets.... Just remember that your ignition key will be different that your door and trunk key now.
Old Oct 18, 2005 | 03:51 AM
Dzaccord's Avatar
Default Re: 95 Accord ignition (HondaTechPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTechPro &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it is pretty easy to install. No real secrets.... Just remember that your ignition key will be different that your door and trunk key now.</TD></TR></TABLE>
That's true and I disconnect my Air Bag as well. There are some rivets on both sides of the ignition that you may have trouble removing but other than that it's pretty simple.
Old Oct 18, 2005 | 08:32 PM
Default Re: 95 Accord ignition (Dzaccord)
Thanks for the suggestions guys, I'll let you know how it goes tomorrow, it's my day off, so I'll be doing it in the am.
tomerzz
Aug 23, 2013 04:21 PM
[713]
Apr 7, 2009 05:02 PM
jsquared22
Oct 28, 2006 12:47 AM
HondaMatic185
Jun 27, 2005 09:54 PM
jasonmmyers
Aug 24, 2004 08:29 PM
