Squeaky Clutch
My clutch has developed a squeak. When I engage the clutch, it has this annoying squeak, like the sound when brakes need to be replaced. Then as I let out the clutch, it makes the same noise. Is it a throwout or release bearing? Pilot bearing? Main shaft bearing or seal, or something like that? I'm useless when it comes to this.
Any suggestions, question , comments, concerns?
It's a 97 Hx w/145k miles on it.
What do I do to fix this?
CF: Squeaky clutch, need opinion on what to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99 Civic EX »</TD></TR><TR><TD CLASS="quote">search, this has been covered many times already...</TD></TR></TABLE>
if it has then u should know the answer and y not just tell him. instead of making a usless post?
It could be all sorts of things. Trial and error is the way to go but definitely look around and search.
Mine was doing the same thing. I would hear a cricket type noise. It sounded rusty at the pedal or behind the pedal. It ended up being my pressure plate.
Good Luck!
~SojournMystical
Good Luck!
~SojournMystical
Solstic
Jun 13, 2012 11:34 AM
