How do you shave letters off the valve cover
Old 10-14-2005, 08:45 AM
gutted-dx's Avatar
Default How do you shave letters off the valve cover
I'm going to paint my valve cover and i was wondering how i could shave the Vtec off
Old 10-14-2005, 08:46 AM
Sleepy_Red_hatch's Avatar
Default Re: How do you shave letters off the valve cover (gutted-dx)
a grinder?
Imperious: Mod of Valor
JDM-EJ1's Avatar
Sand paper?
Old 10-14-2005, 08:50 AM
SE7EN3S's Avatar
A dremmel tool with a diamond bit would work.
Old 10-14-2005, 09:21 AM
gutted-dx's Avatar
Has any of you done it
Old 10-14-2005, 09:24 AM
EJ1 wilcox's Avatar
Default Re: (gutted-dx)
Be careful if you do it by hand with a dremel or something. It's hard to get the surface completely flat.
It can be done, but it takes a while.
I would start out with a dremel to take most of it down, and then once the letters are just barely raised I'd go at it with a hand sander.
Belt sander could work too, but just be careful and go slowly.
Old 10-14-2005, 09:25 AM
JDM-EJ1's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Be careful if you do it by hand with a dremel or something. It's hard to get the surface completely flat.
Belt sander could work too, but just be careful and go slowly. </TD></TR></TABLE>
You always have good advice Lincoln!
Old 10-14-2005, 09:28 AM
SE7EN3S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">It's hard to get the surface completely flat.
Totally Agree!
Old 10-14-2005, 09:30 AM
gutted-dx's Avatar
So you can use a sander, what grit
Old 10-14-2005, 09:47 AM
dividedas1's Avatar
start with a really rough grit...like 80 or even rougher and work your way up to 320 with a sander then take a sanding block and sand it smoother like up to 600-800 if you want a nice smooth finish
Old 10-14-2005, 10:27 AM
PA MATT's Avatar
Default Re: (dividedas1)
don't shave the vtec off.....get a 92-93 valve cover with the H to do it. Less material to grind and most people will pay more for vtec covers anyways. That's if your talking about a d-series at least. Otherwise, it depends on what your going to paint it with. If you're using wrinkle paint, id just use a 4 inch grinder(what i used)...you won't notice the "waves" with wrinkle paint. If your using a high gloss paint, i would grind it down most of the way and then use sandpaper and a block to get it smooth
Old 10-16-2005, 04:49 AM
gutted-dx's Avatar
It's on a b16, i'm just going to use the old grinder
Old 10-16-2005, 06:59 AM
.Steve's Avatar
You could've got another cover for like $15
Old 10-16-2005, 08:16 AM
komat's Avatar
Default Re: (Vado-Ieiunium)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vado-Ieiunium &raquo;</TD></TR><TR><TD CLASS="quote">You could've got another cover for like $15</TD></TR></TABLE>
another valve cover??
where at for $15
Old 10-16-2005, 08:19 AM
gutted-dx's Avatar
Old 10-16-2005, 09:16 AM
xPhantomSolx's Avatar
grinder will work, but also be careful not to remove too much.... that can be BAD.
Old 10-16-2005, 10:09 AM
AnToNy's Avatar
I've seen people use a metal file.
Old 10-16-2005, 04:20 PM
EJ8chu's Avatar
Default Re: How do you shave letters off the valve cover (AnToNy)
LS valve cover doesnt have VTEC on it.....mayb that will fit
Old 10-16-2005, 05:38 PM
Tony_EM1's Avatar
Default Re: How do you shave letters off the valve cover (xxsteve803xx)
when done post pic
Old 10-16-2005, 05:41 PM
khmboostedeh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxsteve803xx &raquo;</TD></TR><TR><TD CLASS="quote">LS valve cover doesnt have VTEC on it.....mayb that will fit
ls valve covers dont fit on the b16, but if they did, can you imagine how many ricers would put a vtec valve cover on there LS motors.
Old 10-16-2005, 06:05 PM
CoreyR's Avatar
Default Re: How do you shave letters off the valve cover (Jeterkm02)
OBX came out with a valve cover that looks exactly like a B-VTEC cover that fits an LS. sad but true
Old 10-16-2005, 06:07 PM
Tyte4Door
Guest
Posts: n/a
How come you wanna shave that off? i'd be happy to have those precious letters engraved in my valve head(i have D15 SOHC non-vtec poo poo ). unless i' was going for ultimate sleeper i'd leave em.
Old 10-16-2005, 06:09 PM
aspec101's Avatar
ricer ****** but b16 valve covers on LS's all the time around michigan. Thinking no one will know.
Old 10-16-2005, 06:28 PM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted-dx &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to paint my valve cover and i was wondering how i could shave the Vtec off</TD></TR></TABLE>
I use a Gillette Mach 3. works wonders and the special soothing strip helps fight oxidation
Old 10-17-2005, 07:10 AM
gutted-dx's Avatar
I think it looks better with out the letters, plus i'm getting the different plug cover, makes the bay look alot better
ShinotakuX
11
06-26-2007 09:52 PM
Pr0ject93hb
01-18-2007 01:32 PM
zccr-xsi
12-19-2005 11:23 PM
DFW
08-29-2005 11:16 PM
pg_thao
03-11-2002 05:55 PM
Quick Reply: How do you shave letters off the valve cover
