coolant inside car after replaceing heater hose. were's it coming from
Old Oct 16, 2005 | 05:49 PM
coot_er's Avatar
Default coolant inside car after replaceing heater hose. were's it coming from
i was replacing one of my heater hoses, the one the goes frome the firewall to the back of the block and is straight with just a V in the center. anyhow it would not come of so i pulled on it hard. i finally got it off and the new one on, but when filling up the radiator i found that the passenger footwell was full of coolant. i can tell that its coming out somewere behind the radio. what could it be? were do i begin?
Old Oct 16, 2005 | 05:52 PM
kulangot's Avatar
Default Re: coolant inside car after replaceing heater hose. were's it coming from (coot_er)
maybe the heater hose..if you got it to tite you may have bent it...that's what happened to me..
Old Oct 16, 2005 | 06:01 PM
coot_er's Avatar
Default Re: coolant inside car after replaceing heater hose. were's it coming from (kulangot)
the heater hose inside the car or were? not to sound dumb but i need more details
Old Oct 16, 2005 | 06:09 PM
kulangot's Avatar
the heater hose you put on...the heater core goes throw the firewall and if its leaking it will go in the car..
Old Oct 17, 2005 | 02:14 PM
coot_er's Avatar
so you think its just the heater hose i put on? that wouldn't totally surprise me because it was just a straigt piece i got for free at auto zone and it seemed like it was just a hair too big. is there a chance i could have broken something just from tugging on it??
Old Oct 17, 2005 | 04:34 PM
coot_er's Avatar
whats on the other side of the firewall that connects to the heater core? are they just more rubber lines? what im getting at is would it be possible to break it from tugging on the outlet hose?
Old Oct 17, 2005 | 04:50 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
bad mistake...
What you should have done was split the hose with a razor blade
and worked it from side to side until it came loose...
Inside will look something like this:
http://www.overclockers.com/ti...e.jpg
What you can do for the time being
is loop a hose between the in and the out hoses of the engine
to by-pass the heater core..
Old Oct 17, 2005 | 05:09 PM
si0385.'s Avatar
Default Re: coolant inside car after replaceing heater hose. were's it coming from (88DXCRX)
sounds like you cracked the heater core when u were wrestling with the hose, cutting the hose vertically with a rasor would have been ur best bet, till u can find out just make a loop in the hoses and bypass the heater core if it stops leaking inside the car than that would be youre problem
Old Oct 17, 2005 | 05:38 PM
Slow ass EF's Avatar
Default Re: coolant inside car after replaceing heater hose. were's it coming from (turbodreamz0385)
buy a new heater core, it sounds like you need it.
Old Oct 17, 2005 | 07:28 PM
coot_er's Avatar
Default Re: coolant inside car after replaceing heater hose. were's it coming from (slow *** ef)
so the rubber hose that i yanked off is directly connected to the metal lines? meaning it is those metal lines shown in the picture above that are sticking through the firewall?
LGxGirL
Nov 26, 2012 10:58 AM
stakskits
Feb 21, 2010 02:11 PM
Soda Popinski
Nov 7, 2005 12:39 PM
R.S.
Sep 4, 2004 12:55 PM
