ENDYN BREATHER KIT / Z10 BREATHER PLUG "Where can I get one"
Here is the pic:
I'm looking to purchase one. I know there was an older version with a different mount style. I 'm looking for the one as pictured, the one that uses the clamp like turbonetics.
Also looking on getting the Z10 OEM breather box plug
Anyone on HT a dealer for Endyn and Z10.
Thanks.
Thanks.
yah I know the exact part number for those fittings from honda (very hard to find) and I also know the part number for that plug so you can get it from your local Kragen auto parts. No fancy names just what works and looks clean
Won't post them, but you can Pm me for them
.Won't post them, but you can Pm me for them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">I need one of those plugs! Does it plug up where the PCV valve goes?</TD></TR></TABLE>
yea i got mines from z10 for like $20shipped i think!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgsrekk »</TD></TR><TR><TD CLASS="quote">i have endyn catch can for sale
http://hondamarketplace.com/zerothread?id=1403995</TD></TR></TABLE>
Kit is $164 from Endyn. $200 kinda steep don't you think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slimm-rw- »</TD></TR><TR><TD CLASS="quote">I have the plug, new and unused. name your price mang. </TD></TR></TABLE>
Is it the Z10 part number Z10-4018? How about $20 like the NAtural_asPIRATIONs mentioned?
Anyone else???
Anyone else???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felix. »</TD></TR><TR><TD CLASS="quote">why would one plug up the pcv ? </TD></TR></TABLE>
B/C the B20 Valvecover looks nicer than my B18b valvecover. The b20's have the PCV going into the valvecover and not the black box on teh back of the block like most B-series do. So since I do not need 2 PCV valves, I want to block one.
the plug he is talking about or has in the smaller pic goes where the pcv box goes and cost like 75
I went through this so I know it ain't going to be cheap if u do it right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 »</TD></TR><TR><TD CLASS="quote">the plug he is talking about or has in the smaller pic goes where the pcv box goes and cost like 75
Wonder how I plug up the pcv valve spot on the valvecover then?
</TD></TR></TABLE>Wonder how I plug up the pcv valve spot on the valvecover then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cptengineer »</TD></TR><TR><TD CLASS="quote">yah I know the exact part number for those fittings from honda (very hard to find) and I also know the part number for that plug so you can get it from your local Kragen auto parts. No fancy names just what works and looks clean
.</TD></TR></TABLE>
why is everyone so secretive about this ****? I remember posting up about how to get the fittings and it was like damn someone let the cat out of the bag.
I didnt even know i had a secret at the time?!
.</TD></TR></TABLE>why is everyone so secretive about this ****? I remember posting up about how to get the fittings and it was like damn someone let the cat out of the bag.
Actually it is cheap if you do it right and it will look nice.
Well in the first place I started to add this to B20 blocks a few years back since their PVC system is very inadequated when adding forged pistons and reving to 9000RPM, this creates some blow by and alot more windage, by properly evacuating the crankcase you remove the gasses from under the piston which causes an opposite pressure on the under side. So eventually this became standard in all the bolcks I do, sice I rearlly use factory pistons, plus I've seen about a 5hp gain with this on most dynos. Ideally vaccum in the case is desired but then you'd need a vaccum pump. Anyways sorry for holding back I recieved quite a few PM's So here you go guys:
Breather plugs from honda= 11107-PK2-003, this is a water outlet fitting found on prelude blocks H22. These will take place of two large (14mm) allen plugs on the back side of the B-series blocks. These are usually on there really good. cost on these are $8.75 each.
Kragen auto parts= pt #: 555-104.1 this is a "34.22mm deep cut EXP. plug steel"
in other words is a metric freeze plug that fits perfectly and tight, cost is about $1.50. I used a little honda bond just to be sure and wipe the excess.
Hope this has helped everyone
The two fittings on the right come from the back of the block on the left is from valve cover and the bottom is left open to drain back to the little fitting right below intake runner #2.
</TD></TR></TABLE>Actually it is cheap if you do it right and it will look nice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gldndrgn14 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1199935
https://honda-tech.com/zerothread?id=697498</TD></TR></TABLE>
I was just about to post up those two links. Whoever said the part numbers are hard to find is just plain silly. You'll find ALL the needed part numbers in the first link.
haha i went to the kragen website they list $5.24.
http://www.partsamerica.com/Pr...55104
oh btw, does it not matter that its not aluminum?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Good info in this thread. I finally broke down and bought a catch can for the race car.</TD></TR></TABLE>
Definately. Good look on the kragen plug much cheaper than z-10 though it is steel.
I went with the z-10 because i didnt feel like messing with trying to get plugs to fit. This should help alot of people cuz the z-10 is like 20 plus ship. But is is a real nice piece.
i read somewhere that the plug should be made of aluminum, so that the block and the plug will expand and contract at the same rate. i dunno what effect having a steel plug will have
RACEPAK
Jul 24, 2006 08:59 AM
