Oil filter problem
Old Oct 16, 2005 | 11:55 AM
89turbota's Avatar
Default Oil filter problem
My friend has an 87 LXI and twice oil has blown the filter. The first time it herniated the gasket and did no damage to the filter. The second time the cannister part of the filter separated from the base that screws to the housing. After the first incident, she changed the filter and I thought it might have been a defective gasket. The car was then driven over a mountain pass and it was fine and then one morning when the car was started oil sprayed all over the ground again. I know there is a pressure regulator in the pump but that usually either causes no flow or no pressure if it is defective. Anybody know something specific about Honda cars that may cause this problem? I haven't consulted a Honda Tech, but all other techs are baffled. Thank you.
Old Oct 16, 2005 | 12:23 PM
casmello's Avatar
I think some hondas can use 2 different types of oil filters with different size threads, I would check that? otherwise Im not sure sorry man =X
Old Oct 16, 2005 | 02:35 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Oil filter problem (89turbota)
go to your dealership and get the proper filter for your make/model
Old Oct 16, 2005 | 06:21 PM
HondaTechPro's Avatar
I have not seen this conditon on any Honda engines. I have heard of it happening on other makes, but no firsthand experience. A clogged oil filter might cause something like this, however the oil system has an oil filter bypass valve designed to prevent this. I can only think that there is an issue with either a defective gasket... or a low quality oil filter. I recommend only the OEM filters be used.
Ozne99
19
Aug 30, 2010 06:04 PM
r33dm0n3y
Jun 23, 2009 05:30 PM
devin_hoang
36
Mar 24, 2009 01:08 PM
daman895
Dec 12, 2002 03:21 PM
Flux
Mar 24, 2002 07:43 PM
