I Accidently Popped the Rear-View Mirror Out: now what?
I was looking for something between the seat and the center console and the mirror just fell on me when I accidently pushed up on it. Now there is a washer/bracket + spring serperate from the mirror off the windshield. How do I put it back together?
Modified by vinuneuro at 10:44 AM 10/16/2005
If I remember correctly, you have to remove the screw which will release the washer and a spring. Then what you do is slide the mirror into the bracket and tighten the screw, and it should hold in place. Have a friend help you if possible, that's what I did.
