JUN flywheel clutch
Old Mar 5, 2002 | 07:19 PM
SCsol's Avatar
Default JUN flywheel clutch
hey there guys im buying a clutch for the JUN light flywheel in thinking ITR clutch and pressure plate what do you guys think and will i have any problems with this thanks for the help
Old Mar 6, 2002 | 06:33 AM
Kamin's Avatar
Default Re: JUN flywheel clutch (lowsol)
its a stock clutch
dont bother
go buy a real performance clutch.
clutchmaster, clutchnet, exedy etc. etc.
[Modified by KAMiN, 7:33 AM 3/6/2002]
Old Mar 6, 2002 | 10:23 AM
eg6ajk's Avatar
what setup? if you are making less then 180whp then there should be no problems with the ITR clutch, if its more then look into the aftermarket world...
Toda, Cusco, Excedy, Jun and act offer all kinds of different clutches to match your setup....
from expirences, I had ITR clutch/flywheel combo on my B16a as well as 3 puck race setup from Toda (including the flywheel), on this mild application (close to 160whp), there was no need for such holding power for steet setup think twice, especially if you do alot of driving in traffic (the foot will do alot more work, the engagment is rough, so winter or wet weather conditions will yield spinning tires almost at all times)
bubblehead
May 31, 2006 02:39 AM
CDN Yellow ITR
Dec 5, 2003 12:59 PM
VTECJUN
Sep 24, 2003 08:43 AM
qWiK hYbRiD
Nov 30, 2002 04:10 PM
cyberx
22
Oct 21, 2002 06:17 PM
