VTEC and synthetic oil...do they "mix"?
Old Oct 15, 2005 | 10:56 PM
MestizoRacer310's Avatar
Default VTEC and synthetic oil...do they "mix"?
I've heard from different sources that it is bad to run synthetic oil in VTEC motors. Is this at all true?
Old Oct 16, 2005 | 01:05 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: VTEC and synthetic oil...do they "mix"? (MestizoRacer310)
false
Old Oct 16, 2005 | 04:55 AM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard from different sources that it is bad to run synthetic oil in VTEC motors. Is this at all true?</TD></TR></TABLE>
and who said this, matt damon?
Old Oct 16, 2005 | 07:16 AM
MenaceL.A.671's Avatar
Default Re: VTEC and synthetic oil...do they "mix"? (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">false</TD></TR></TABLE>
wheres the link you getting the info. from?
Old Oct 16, 2005 | 11:10 AM
Default Re: VTEC and synthetic oil...do they "mix"? (m2slsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m2slsvtec &raquo;</TD></TR><TR><TD CLASS="quote">
wheres the link you getting the info. from? </TD></TR></TABLE>
So you think running synthetic oil in a vtec motor is bad? dont be an asshat
Old Oct 16, 2005 | 11:16 AM
projectTeG's Avatar
if it was bad...then honda wouldnt recommend it huh?
Old Oct 16, 2005 | 01:18 PM
SkankyEJ7's Avatar
Default Re: (projectTeG)
where does honda say dont use synthetic
Old Oct 16, 2005 | 01:19 PM
projectTeG's Avatar
might wanna read that statement again....honda recommends it to be used with thier engines.
Old Oct 16, 2005 | 01:28 PM
rodimus's Avatar
let's just end it all here and stop all the arguments.
synthetic oil is not bad to use.
if you have leakage or burn off, then you probably need to replace your seals, or have bad rings.
that's pretty much about it.
Old Oct 16, 2005 | 01:37 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: VTEC and synthetic oil...do they "mix"? (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">
and who said this, matt damon?</TD></TR></TABLE>
LMFAO
Honda does say to use it on the vtec motors
Old Oct 16, 2005 | 02:24 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">might wanna read that statement again....honda recommends it to be used with thier engines.</TD></TR></TABLE>
no i was asking where it says this, i use synthetic
Old Oct 16, 2005 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">So you think running synthetic oil in a vtec motor is bad? dont be an asshat</TD></TR></TABLE>
N/M....cleared up through PM with PURPLETERROR........
Modified by MestizoRacer310 at 11:37 AM 10/17/2005
Old Oct 16, 2005 | 03:39 PM
projectTeG's Avatar
i was told that if your car ws ran with non-synthetic and you switch to syn its ok, but you cant go from syn to non-syn
Old Oct 16, 2005 | 07:33 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">i was told that if your car ws ran with non-synthetic and you switch to syn its ok, but you cant go from syn to non-syn</TD></TR></TABLE>
you were told wrong.
Old Oct 16, 2005 | 08:10 PM
RudeBwaiSi's Avatar
Default Re: (EVOL)
I heard the same argument. . . that you can't or shouldn't switch back once you start using synthetic.
Old Oct 16, 2005 | 08:50 PM
rodimus's Avatar
Default Re: (RudeBwaiSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeBwaiSi &raquo;</TD></TR><TR><TD CLASS="quote">I heard the same argument. . . that you can't or shouldn't switch back once you start using synthetic.</TD></TR></TABLE>
i've switched back a couple of times.
Old Oct 16, 2005 | 10:53 PM
projectTeG's Avatar
Default Re: (EVOL)
you were told wrong. </TD></TR></TABLE>
oh ok,..lol, i really wasnt worried about, so there wouldnt be any problems taking a car from synthetic oil to non-synthetic right?
Old Oct 18, 2005 | 11:21 PM
Jago's Avatar
Matt Damon
Old Oct 19, 2005 | 07:23 AM
ITR-2001's Avatar
Unless you meant to say LSD tranny?
Old Oct 25, 2005 | 02:32 PM
Civic SiR-S's Avatar
Default Re: (ITR-2001)
man your crazy synthetic oil its great, i think it better than the normal oil, because, last month we change the rod bearings from the h22 of my brother, 3 years of ******* hard kick *** to the engine but with synthetic oil, + the use of the engine before my brother buy it, its a h22 JDM, and the bearings was so ******* new i dindt believe it, the where in pretty good conditions, we change them because we hace already buy a new set, so we put the new ones, but the old ones where the OEM ones and good looking hehehe
i dont know i recomend it
dirtyharryhatch
11
Jun 20, 2008 09:57 AM
hotroddb8r
Nov 18, 2007 06:50 AM
SwiftTypeR
Feb 6, 2006 10:39 AM
REDTOPAlchemy
Jul 11, 2004 11:36 AM
tegnchewy
Oct 4, 2003 04:39 AM
