Shifter is pulling out of gear on burnout or launches.
Old Oct 15, 2005 | 09:04 PM
msmotorsports's Avatar
Default Shifter is pulling out of gear on burnout or launches.
I'm running the new Long shifter from G-Force. It is mounted solid to the chassis and has a direct linkage to the input shaft on the trans. The trans is a 95 GSR hydro. I am also running the Tilton twin disc cerametallic clutch. The motor has been mounted solidly to the chassis and has NO movement under any condition. My problem is that during a burnout(2nd Gear burnout) or during a launch when alot of torque is applied the shifter will come out of gear and go into neutral. It almost looks like the shifter is jolted very hard and forced into neutral. Can it be the input shaft in the tranny that is forcing the tranny out of gear? Synchros seem to be fine as the gear is not hard to select or does not grind at all. What could cause the shifter to come out of gear on the launch and burnout?
Old Oct 17, 2005 | 05:45 AM
Mista Bone's Avatar
D Tranny Guru
bad motor mounts.........
HopelessAccord
Nov 20, 2018 07:11 PM
LShatchie
18
Feb 24, 2006 08:00 PM
DC5SMunky
Aug 13, 2005 09:43 AM
h22pwr
Jun 7, 2005 11:33 AM
