Gas 5 months old?
Old Oct 15, 2005 | 07:22 PM
JDM00SI's Avatar
Default Gas 5 months old?
sup,
I've been doing a full swap, turbo set up on my car etc...it has the same gas it had about 4-5 months ago. Is the gas still good/? its 93 octane. it will be used on a turbo car.....
Is this healthy or risky? Should i drain it and put new gas? Thanks
Old Oct 15, 2005 | 07:23 PM
JDM00SI's Avatar
Default Re: Gas 5 months old? (JDM00SI)
just bumping it up y0
Old Oct 15, 2005 | 07:40 PM
blu3g's Avatar
I heard that gas loses octane when it sits around for a long period of time. Of course I only heard this so I don't know. I guess it's better to be safe than sorry.
Old Oct 16, 2005 | 06:14 AM
d16dcoe45's Avatar
Default Re: Gas 5 months old? (blu3g)
You mean the gas was sitting in the tank, and now you want to start it up after 5 months, correct? Well, they do make gas stabilizer--which helps keeps the gas fresh, as it goes stale after sitting for about a month. The thing is--you need to put the gas stabilizer in before you let the gas sit!! I would do this--stick a suction pump or something of the like through your filler--suck as much as that old gas out, and get rid of it. When my motor spun a bearing and I knew it would be sitting for a while--the first thing I did was suck out the gas and put it into another car I was driving at the time--so it didn't go to waste. Any gas that old--is not worth it on a new build.
Old Oct 16, 2005 | 06:16 AM
JDM00SI's Avatar
oh so use like one of those suction things? im going ot be sucking up gas for a while lol.
Old Oct 17, 2005 | 05:43 AM
Mista Bone's Avatar
D Tranny Guru
Run the tank out or pull the drain plug.......... it will be fine for start-up and break-inm just no boost.......
Old Oct 17, 2005 | 09:23 AM
JDM00SI's Avatar
ok thanks
Old Oct 17, 2005 | 09:55 AM
dinko's Avatar
Default Re: (JDM00SI)
take the tank off and drain in
try to search around for how some of the domestic guys clean out their gas tanks when they do restorations. just try to imitate their process
Old Oct 17, 2005 | 10:34 AM
spoonek9's Avatar
Gas has a shelf life of 6-12 months, typically. Is this a full tank of 93?
Old Oct 17, 2005 | 07:04 PM
JDM00SI's Avatar
less than 1/4th
pepsi813
Honda CR-V & Element
May 19, 2019 12:41 PM
pootie.teng
Jul 18, 2007 05:43 AM
ekdriven
Jun 8, 2004 08:39 AM
CleanCL
Mar 21, 2002 11:49 AM
