no spark, tried everything, help!
ok my rex isnt gettin spark. 88 si with z6 head, p28 ecu. wiring from the ecu is correct. dizzy is good (put it on my friends eg and it started right up), new plugs and wires. when i remove the dizzy and put it in it will start up for 1 second and then die and just crank after that. ive seen spark when i was testing maybe 1 out of 30 times trying. i know all the wires from the dizzy trace back to the ecu in teh correct positions (used a multimeter), battery is good, i cant see any bad fuses? if my plugs arent gapped correct would it not spark? i mean how much space would it take to not have a spark? someone help!
delsolo95
Jun 13, 2011 06:15 AM
95turbohatch
24
Apr 7, 2004 08:07 PM
