code 17 VSS in 0bd0 crx
Old Oct 15, 2005 | 04:06 PM
HT Chaplain's Avatar
Loved
Default code 17 VSS in 0bd0 crx
My car is giving code 17 which is VSS but i didnt realize it had a vss just a speedo cable that pulgs into the dash? How do I fix it?
Old Oct 15, 2005 | 04:13 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: code 17 VSS in 0bd0 crx (HT Chaplin)
Is your speedometer working?
If not,check the cable as described here at the bottom:
https://honda-tech.com/zerothread?id=1325930
If the speedometer works,and you still get the code
it may be in the cluster itself...
Old Oct 15, 2005 | 04:14 PM
RCautoworks's Avatar
Either you have a short in the circuit or the vss is bad all together.
Old Oct 15, 2005 | 04:17 PM
Loved
Default Re: code 17 VSS in 0bd0 crx (88DXCRX)
I was driving and the speedo stopped working then the code popped up. The cable is still in the tranny. I didnt realize there was a vss? is it back of the cluster?
Old Oct 15, 2005 | 04:42 PM
88DXCRX's Avatar
It is inside the speedometer..
If the speedo is not working,Most likely the cable broke
inside the cable housing or it may have come loose at the transmission.
Old Oct 15, 2005 | 05:15 PM
alecjoesph's Avatar
its your cable, same thing happened to me. Which motor are you running.
Old Oct 15, 2005 | 07:09 PM
90si-rex's Avatar
Default Re: code 17 VSS in 0bd0 crx (alecjoesph)
definitely sounds like the cable......same thing happened to mine. basically just shredded and was really ugly. you can get a new for about $15-20 just about anywhere. i think i paid about $15.95 + tax for mine.
Old Oct 25, 2006 | 07:41 PM
crxben's Avatar
Default Re: code 17 VSS in 0bd0 crx (90si-rex)
I also had the same thing happen to me. First i kept getting a vss code, it kept happening for about 2 weeks. I just kept ignoring it. Then my spedo quit working. I took the cluster out and the spedo cable out of the tranny. The cable was in good condition. I put it back in the tranny and drove to see if the cable moved and it did. So I put everything back together. After doing that everything work again. No more vss code and spedo works just fine. Just take everything apart and inspect before throwing money at parts.
Old Oct 25, 2006 | 08:18 PM
KFBhonda's Avatar
Default Re: code 17 VSS in 0bd0 crx (crxben)
thanks crxben.
i have been having the code lately, but it usually takes at least a half hour of driving or more to throw the CEL at me. i often shut the car off and start it back up again as a ghetto fix for it...
but the speedo and tach work just fine, so i was thrown for a loop as to what the deal is. after your post, i guess i will just take off the cluster and inspect connections and troubleshoot it, and hopefully that will fix it. it worked for you, huh?
Old Oct 25, 2006 | 08:26 PM
crxben's Avatar
Default Re: code 17 VSS in 0bd0 crx (KFBhonda)
Yeah it worked for me... haha I did the same thing with the cel, I would turn off the car to clear it. Hopefully everything works out for you.
dusterbd13
Oct 19, 2009 06:47 PM
EF9 JAMS!!!
Dec 10, 2006 10:26 AM
MattsHatch93
Jan 10, 2006 06:23 PM
90AcuraIntegra04
Aug 7, 2005 05:04 PM
Joebroni
May 29, 2005 12:43 PM
