car not starting please help
Old Oct 15, 2005 | 02:19 PM
jsbaby's Avatar
Default car not starting please help
I have replaced the starter, battery, fuel filter, and pump and still my 87 accord will not start... it turns over but no gas is getting to the carburater... if i poor gas into carburater it will start and run long enough to burn off the gas then die... what do I do... i am out of ideas please email me with any suggestions at jsbaby122904@aol.com thanks
Old Oct 15, 2005 | 03:27 PM
tyro's Avatar
Default Re: car not starting please help (jsbaby)
Clogged line or strainer?
Old Oct 15, 2005 | 03:36 PM
P_Adams's Avatar
Regardless of what model it is DX, LX LXi, there are two things which must be checked first,
1) Fuel Pump Fuse (It IS Electric Tank Mounted, Yes?)
2) Main Relay (I know where it's found on 5th Gens, but not 3rd (so you'll have to ask someone else (sorry))
Start with those first.
More than likely, it you were to check, you don't have electrical power to the pump.
P
Old Oct 15, 2005 | 05:50 PM
deserthonda's Avatar
as P stated since u are not getting gas u need to chk fuel pump fuse,,,,,,if fuse is ok...,,u stated u just replaced fuel pump .. make sure all work is done properly and connector is properly snapped in,,,,,,,,chk to make sure u are getting power and ground at the pump......if u are, make sure the line for the fuel filter the 1 at the tank is not kincked,,if line is ok,,,fuel pump must be bad ,,,,1 other test u can do even before u do all that.............remove fuel line going into carb, have someone crank the car ,, if no fuel ,problem most likely to pump,pump fuse , no gas in car , or filter ,,,,, chk and post results
Old Oct 16, 2005 | 08:59 AM
JTB's Avatar
JTB
Default Re: car not starting please help (deserthonda)
when you turn the key on watch the check engine light (cel) as the cel goes off you will hear a relay click does this happen? if not you have a bad main relay very common in warm weather if it does click the proced with dh's troubleshooting! where did you get the pump at i had a customer bring an aftermarket pump in for us to put in and it was bad it took 4 pumps to get a good one! just no honda quality there mabye if you can buy a oem honda one if you alraedy din't
Old Oct 16, 2005 | 09:04 AM
JTB's Avatar
JTB
Default Re: car not starting please help (JTB)
hey dh have you ever seen these web sites?
http://www.acuraautomotivepart...y.jsp
http://www.hondaautomotiveparts.com/
they have an online honda parts catalog i find very useful if i am not at work and cannot get access to the in network or to look up acura parts at work because we are only honda and there is no acura dealer for like 120 miles so we do alot of acura work!
Old Oct 16, 2005 | 02:10 PM
87 accord with carb.................no chk engine lite ....., no main relay ...
Old Oct 16, 2005 | 02:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTB &raquo;</TD></TR><TR><TD CLASS="quote">hey dh have you ever seen these web sites?
they have an online honda parts catalog i find very useful if i am not at work and cannot get access to the in network or to look up acura parts at work because we are only honda and there is no acura dealer for like 120 miles so we do alot of acura work! </TD></TR></TABLE>
i have seen majestic honda ,,the other i had not.........thanks..
Old Oct 16, 2005 | 08:10 PM
JTB's Avatar
JTB
sorry totaly forgot about the whole 87 carb... good catch not up to date with carbs mostly 90 and up stuff for me
Old Oct 18, 2005 | 02:29 PM
JTB's Avatar
JTB
did you ever find the problem?
integraboi415
Aug 31, 2006 02:21 PM
Shaun
Jun 22, 2006 03:24 PM
gnar kill
Nov 18, 2005 02:09 PM
trianglegreg
Oct 29, 2005 08:51 AM
lowboost civ
May 3, 2003 07:48 PM
