exhaust sizing
Old Oct 15, 2005 | 02:08 PM
huge230's Avatar
Default exhaust sizing
what kind of numbers will justify 3 inch exhaust?
Old Oct 15, 2005 | 02:14 PM
EG6-SIRII's Avatar
turbo otherwise stick to 2.5"
Old Oct 15, 2005 | 02:17 PM
huge230's Avatar
Default Re: exhaust sizing (huge230)
see i plan on turboing my h22 in the spring but dont really want to get a 2.5 inch and then a 3inch in the spring so i was thinking 3 inch
Old Oct 15, 2005 | 02:22 PM
importdreamer's Avatar
I would go with 3 inch if you are DEFINITELY turboing it. It wouldnt hurt to drive around like that for a while , but dont forget that you may notice a difference in performance with the lessening of back pressure.
Old Oct 15, 2005 | 02:26 PM
huge230's Avatar
Default Re: exhaust sizing (importdreamer)
ok 3 inch it is
also have any of you guys ever fabbed up your own using mandrel bent 90s and 45s?
how did it work out?
Old Oct 15, 2005 | 02:34 PM
did it on a CRX and it was horrible. lots of leaks too many c clamps eventually it all came off and we had it done right. I wouldn't recommend it especially if you turbo it. You dont want the exhaust going to **** when you invest that much money in it.
Old Oct 15, 2005 | 02:43 PM
huge230's Avatar
even with a mig welder and someone thats really knows how to weld? Just that muffler shops areound here are stupid and my buddy is a blacksmith nand a great welder. i wouldnt clamp anything jst weld and use a flange or 2
Old Oct 15, 2005 | 03:00 PM
Welding is different you should be fine then.
Old Oct 15, 2005 | 03:07 PM
huge230's Avatar
i might give that a shot. ill save alot of money. you just used clamps?
Old Oct 15, 2005 | 04:36 PM
FalkenSiR's Avatar
Just go with 3" while you are at it. It'll be loud depending on your ex components, but it'll save you money in the long run.
Old Oct 15, 2005 | 04:43 PM
huge230's Avatar
Default Re: exhaust sizing (fast88std)
what do you think of welding up a system instead of a shop? ever done it?
kou-integra98
Oct 11, 2013 07:20 AM
A.E Motoring
Mar 8, 2006 05:53 AM
a1320addict
Jan 9, 2005 06:23 AM
a1320addict
Jan 8, 2005 09:16 PM
n0pinitr0us
Dec 23, 2004 09:43 AM
