92 W/H22a swap NEED HELP!!! wont fire
Old Oct 15, 2005 | 01:53 PM
prelude72569858's Avatar
Default 92 W/H22a swap NEED HELP!!! wont fire
ok just put the h22 in and it wont fire (injectors ornt turning on) i have the check engine light on for electric load detecor and o2 sensor, they were fine before
Old Oct 15, 2005 | 02:07 PM
tdo's Avatar
tdo
Default Re: 92 W/H22a swap NEED HELP!!! wont fire (prelude72569858)
did you wire up a resistor box?
Old Oct 15, 2005 | 02:54 PM
Default Re: 92 W/H22a swap NEED HELP!!! wont fire (tdo)
yep its in there
Old Oct 15, 2005 | 03:33 PM
tdo's Avatar
tdo
compression
spark
fuel
timing
do you have all of that?
Old Oct 15, 2005 | 06:25 PM
ya all exept fuel, there is no pulsating ground going to them from the 3 resistor boxes iv tried
Old Oct 15, 2005 | 06:27 PM
there is plenty of pressure in the AEM rail
Old Oct 15, 2005 | 07:06 PM
tdo's Avatar
tdo
how do you have the resistor box hooked up?
Old Oct 22, 2005 | 06:56 PM
its plugged in to the engine harness
Old Oct 25, 2005 | 12:46 AM
tdo's Avatar
tdo
what wire harness did you use? the prelude one? or civic one?
check the ohms on the injectors and resistor.
Old Oct 25, 2005 | 04:18 AM
kulrevon's Avatar
its a prelude isnt it? stock harness? I dont know why he seems to think theres something wrong with that?
does the fuel pump turn on?
Also when you turn you ignition on does your check engine light come on for a sec then go off?
Old Oct 25, 2005 | 06:43 AM
ShinobiLude's Avatar
Default Re: 92 W/H22a swap NEED HELP!!! wont fire (kulrevon)
From what I understand...the 92 Lude comes with the resistor box anyway...so all your would have to do is just plug in those 345 injectors and your ready to go. I mean...i might be wrong...but kulrevon never let me down before.
Old Oct 25, 2005 | 07:14 AM
mgags7's Avatar
make sure youre getting signal to the injector wires....take a test light to them and try cranking....
Old Oct 25, 2005 | 07:18 AM
Finest's Avatar
Default Re: (mgags7)
What ECU are you using? What type of injectors are you using?
Old Oct 25, 2005 | 08:15 AM
adrais's Avatar
Default Re: (Finest)
I had this same problem when i put mine in. Dumb mistake, but we didnt ground one of the wires that needs to be grounded. So, another thing to check is for all wires to be connected to where they need to be. Mine wasnt connected down below the distributer (we couldnt see it, so obviously looked over it)
Old Oct 25, 2005 | 12:20 PM
tdo's Avatar
tdo
Default Re: (adrais)
im sorry for soem reason i though i was in the civic or hybrid forum .
yea your wire harness should be wired up for all that.
check if the resistor is working then the injectors and if they're getting the right ohms and volts then check the ECU. then if it still dont work then there might be a open in one of the wires. If that dont work then it might not even be a electrical problem.
georgen316
Oct 17, 2013 11:28 AM
solsquad27
May 15, 2012 11:54 PM
4.8t
Mar 31, 2010 04:57 AM
Hatchls1
Dec 16, 2008 06:00 AM
Preludes'R'Us
Jul 14, 2005 04:09 PM
