'96 EX LCAs in DX
I have a '96 DX which I want to put a front anti-sway bar into but, since my car does not have a stock bar, I would need to get LCAs that had the bar stock. I believe the EX has a front anti-sway bar stock, is this true? And second, if I go to a junkyard and pull the LCAs off of an EX/Si do you think they'll bolt up fine without much if any modification? Thank you.
As long as I dont have to take out any more Metal Gears
Yes EX, LX and SI LCA's will bolt up directly, but the way the EX,LX vs. SI sway bars hook up to ther respective LCA's are different. So find out what kind of bar u will be using and get the corresonding LCA, either EX/LX or SI
Hemix
Dec 6, 2006 04:17 PM
whitelightning
Feb 21, 2006 11:15 AM
BanEL
Mar 20, 2004 06:33 AM
