OBD II Code P0118 Help
Old Oct 15, 2005 | 11:16 AM
6E LUDE's Avatar
Default OBD II Code P0118 Help
I went to autozone and they did a free scan of the check engine light on my car and it came up with a code P0118 and it was "Engine Coolant Temperature Circuit High Input". Has anyone have this problem before? I could really use some help with it.
Setup:
IN MY SIGNATURE
Old Oct 15, 2005 | 11:57 AM
6E LUDE's Avatar
^^bump
Old Oct 15, 2005 | 01:13 PM
prelittlelude's Avatar
Default Re: OBD II Code P0118 Help (6E LUDE)
according to your stock sensor in the dash is your car starting to over heat when it throws the code, if the stock sensor sees a normal temp, try replacing the coolant temp sensor.
eg9d16turbo
Sep 7, 2011 04:24 PM
deercanbrack
May 14, 2008 03:49 PM
mycrx7
Jan 23, 2007 11:21 AM
MPALUGHI
Jan 7, 2005 05:11 AM
Spence
Sep 29, 2004 08:39 AM
