head swap as simple as it sounds?
I have a 93 vtec. I just bought a head (complete) off a 99 base. Is it truly as simple as I think? Or are there any real differences between the H22a-1 and the H22a-4? I figured I'd need a new head-gasket and that's it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">exact same....it in theory is simple, but as usual there will be something in the way of progress...</TD></TR></TABLE>
hahaha yeah, something always comes along to **** things up
well...if it's the same head, I don't see why this won't work...
other than the electronics being obd2 there is no complication. you will need to switch over obd1 parts, ie injectors, complete wiring harness, possibly EGR stuff.. dizzy
Um, hopefully the bolts will not break on you... The Cam Plate Holder Bolts that is... I've had like 5 bolts broken just trying to put mine back on...
I'd replace them though if I was you... :/
I dunno if anyone else has had this problem though..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 »</TD></TR><TR><TD CLASS="quote">Um, hopefully the bolts will not break on you... The Cam Plate Holder Bolts that is... I've had like 5 bolts broken just trying to put mine back on...
I dunno if anyone else has had this problem though..</TD></TR></TABLE>
cam plate holder?
are you talking about the plate that bolts on top of the cam caps? if you have broken bolts either putting them in or taking them out , someone over torqued them , i have taken my head off numberous times and haven't broken one
cam plate holder?
as i lay dying
Apr 21, 2004 05:48 PM
as i lay dying
Apr 20, 2004 08:45 PM
