crx coverted to obd 1 with code 20
Old Oct 14, 2005 | 09:01 PM
hybridpatient95's Avatar
Default crx coverted to obd 1 with code 20
does any one know how can i get rid of this code 20 electrical load detector.. my car cranks but only when you jump the starter.. also its a home made conversion harness lol.. my main relay is good makes the clicking noise, so is my starter relay.. i cant figure out how to get rid of this code.. HELP ME PLEASE!
Old Oct 16, 2005 | 11:57 AM
locash's Avatar
Default Re: crx coverted to obd 1 with code 20 (frankenfiend 04)
The code 20 should not be affecting the starting of your car, you have multiple problems. The starter issue sounds like a problem with your ignition switch. Also, the most common cause of the ELD code is a broken wire at the underhood fuse box, where the wires for the ELD enter it..
Old Oct 16, 2005 | 06:20 PM
i got the starter problem fixed the car crank fine just has no spark and has a code 20.. so your saying i should have a spark problem with that code?
Old Oct 17, 2005 | 02:15 PM
n-line4's Avatar
Default Re: (frankenfiend 04)
from what i understand, if you have a ELD code, then usually there are alternator or idle problems. i recently put in a chipped P28 and got the code 20 which wasnt there before. i'm not having any idle or electrical problems so i am ignoring the code for now until i know more about it. if you ELD is in fact broken, replace you underhood fusebox. also do a search...
Modified by n-line4 at 6:27 PM 10/17/2005
Old Oct 17, 2005 | 04:47 PM
bump any more opinions thanks man
Old Oct 18, 2005 | 05:19 AM
high_revs's Avatar
new harness and a obd0 to obd1 conversion harness and it will start right up.
Old Oct 18, 2005 | 10:27 AM
how bout no?
Old Oct 18, 2005 | 11:32 AM
high_revs's Avatar
it wont start till you do what i said period....stop waisting your time looking for a problem.
Old Oct 18, 2005 | 12:16 PM
how bout ill waste as much time as i want
Old Oct 18, 2005 | 06:42 PM
k24a4kid's Avatar
I'm a Jackass
you dout my wiring brian?
Old Oct 18, 2005 | 09:10 PM
high_revs's Avatar
Default Re: (turbofienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbofienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">you dout my wiring brian? </TD></TR></TABLE>
its not that i doubt it, but you could of easily made a mistake, even me or any1 else....but im 99% sure its the wiring..
Old Oct 18, 2005 | 09:11 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 &raquo;</TD></TR><TR><TD CLASS="quote">how bout ill waste as much time as i want</TD></TR></TABLE>
you do that...hope its running b4 you get your liscense.
Old Oct 18, 2005 | 09:34 PM
high_revs's Avatar
http://rywire.com/store/produc...d4cf8
Old Oct 19, 2005 | 04:31 PM
code 20 is gone.. still no spark
gizzmo222
Aug 11, 2010 08:24 PM
slowteg0bd1
Mar 4, 2009 09:13 AM
ef-hatchcrap
Jul 6, 2008 07:10 PM
jaczs
Jan 7, 2003 10:21 PM
