tein basic coilovers
Old Oct 14, 2005 | 08:48 PM
xoutlawz00x's Avatar
Default tein basic coilovers
guys i got tein basic coilvers and daily driving its smooth and **** but when i hit a bump the back hits hard as expletive...it lowered to about 2 notcthes left.. is that normal and someone said something about bump stoppers.. i pretty sure they were put on there when they were installed. if some has a pic of what it should look like i would appriciate it thanks...
Also the lower part of the shock where the bolt goes through... the piece thats welded on that the bolt cachtes on broke off.. and now i just just got a nut and bolt on it.. Could that be it
Modified by xoutlawz00x at 6:07 PM 10/16/2005
Old Oct 16, 2005 | 01:14 PM
Default Re: tein basic coilovers (xoutlawz00x)
bump
Old Oct 16, 2005 | 01:17 PM
04k2o's Avatar
they ride pretty good
Old Oct 16, 2005 | 05:05 PM
Default Re: (04k2o)
did u read what i wrote
Old Oct 16, 2005 | 09:23 PM
Dane Cook's Avatar
depends on the car and the spring rates. on my integra it rides too hard. on my hatchback it rides too soft.
Old Oct 21, 2005 | 08:30 AM
Earthworm Jim's Avatar
Depends on your tires too. Every notch matters, I have been riding them for some time now. You just have to adjust it more and more, depending on what you're doing. I'm primarily the only one in the car so it's pretty slammed but if you plan on having people in the car then set it differently. Remember the springs are made to reset themselves to the wieght of your car, nothing else. It takes some tweeking.
Here's my car.
Most recent
Like I said, the springs are going to do there thing but it depends on the reason you're using your car. I hope this helps.
Old Oct 21, 2005 | 01:49 PM
bugzpimpin's Avatar
that nut isn't gonna make a difference...just make sure it's on there tight as a virgin.
Old Oct 21, 2005 | 02:08 PM
akteamster's Avatar
Default Re: (bugzpimpin)
i got the basics on my car too 96 ek...they hit pretty hard but handle much better then my tokico blues.........at first i didnt like them, but u get used to it. u have to sacrifice some comfort for performance some times
Old Oct 21, 2005 | 02:43 PM
MonkeyBoy668's Avatar
Um. Are you sure the springs are on right? I took my HAs into a shop to have them fight the 7 years of rust that had built up on the OEM suspension, and the idiots put the front springs on the rear & rear springs on the front. Why the hell they're listed on Teins site is a mystery to me.
Anyway, that brilliant install made the front very soft and the rear very hard. Sounds like what you're describing.
I ended up yanking them out and swapping the springs myself. Snapped bolts a'plenty, they used air guns during the install - every load bearing bolt was seriously over-torqued, surprised one didn't snap while I was on the road. Impatient idiots with access to power tools get a big from me.
Old Oct 21, 2005 | 03:13 PM
ek_99_SiR's Avatar
Default Re: (04k2o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 04k2o &raquo;</TD></TR><TR><TD CLASS="quote">they ride pretty good </TD></TR></TABLE>
read much?
Old Oct 21, 2005 | 03:17 PM
RedEK9's Avatar
Default Re: (ek_99_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_99_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
read much?</TD></TR></TABLE>
Doubt it
Old Oct 21, 2005 | 05:53 PM
gqtrix's Avatar
Default Re: (RedEK9)
I have tien SS on mine, & I do agree you have to play with them to find the right settings... you can also adjust them with EDFC (if it's compatible)
Old Oct 21, 2005 | 07:07 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (gqtrix)
If it's the SS-P then you can adjust it with the EDFC
Old Oct 21, 2005 | 07:50 PM
viskii420's Avatar
not the ss-p... only type flex.. is w. edfc
Old Oct 22, 2005 | 06:04 PM
Default Re: (viskii420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyBoy668 &raquo;</TD></TR><TR><TD CLASS="quote">Um. Are you sure the springs are on right? I took my HAs into a shop to have them fight the 7 years of rust that had built up on the OEM suspension, and the idiots put the front springs on the rear & rear springs on the front. Why the hell they're listed on Teins site is a mystery to me.
I ended up yanking them out and swapping the springs myself. Snapped bolts a'plenty, they used air guns during the install - every load bearing bolt was seriously over-torqued, surprised one didn't snap while I was on the road. Impatient idiots with access to power tools get a big from me.</TD></TR></TABLE>
Guys thanks alot for responding..
yea im pretty sure the springs are on right.. the thicker ones in the back and skinner in the front.. let me knwo if that right..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akteamster &raquo;</TD></TR><TR><TD CLASS="quote">i got the basics on my car too 96 ek...they hit pretty hard but handle much better then my tokico blues.........at first i didnt like them, but u get used to it. u have to sacrifice some comfort for performance some times</TD></TR></TABLE>
your right i love the way they handle..
i guess ima have to just deal with it.. i was just wondering
Old Oct 22, 2005 | 06:43 PM
booty7's Avatar
Default Re: (xoutlawz00x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x &raquo;</TD></TR><TR><TD CLASS="quote">
yea im pretty sure the springs are on right.. the thicker ones in the back and skinner in the front.. let me knwo if that right..</TD></TR></TABLE>
don't know if Tein is selling a newer version of the Basics, but..... I had my full suspension off this week and was looking at the springs.. I'm running the Basics also, on a 92 hatch, and there is no difference in size between my 7 kilo springs and my 3 kilos. These are the rates I received from Tein when I ordered my kit and they had little stickers on them to tell which was which. Thats what it kinda sounds like to me, maybe you got the rates reversed...
Old Oct 22, 2005 | 08:36 PM
Default Re: (booty7)
thanks ill check em out
Old Oct 27, 2005 | 01:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x &raquo;</TD></TR><TR><TD CLASS="quote">yea im pretty sure the springs are on right.. the thicker ones in the back and skinner in the front.. let me knwo if that right..</TD></TR></TABLE>
My fronts are noticeably thicker than the rears. But again I have an old TypeHA set, maybe Basic are different.
Another clue that the springs are wrong is if perches are set REALLY high in the front and really low in the rear (rode very low with the perch about 1/2" from the bottom of it's adjustment range). It's the only way you can get an even ride height if they're swapped.
Nysh
Suspension & Brakes
Jun 6, 2008 10:29 AM
numbnuts22715
Suspension & Brakes
Dec 28, 2005 12:52 PM
xoutlawz00x
Suspension & Brakes
Oct 17, 2005 08:46 PM
beat_nut
Nov 26, 2004 10:41 AM
ophdehEEzY
Sep 5, 2004 12:03 PM
