Foglights don't work after HID install (97 Civic)
Old Oct 14, 2005 | 05:42 PM
christhereefer's Avatar
Default Foglights don't work after HID install (97 Civic)
Just installed an aftermarket HID system in my 97 hatch and now my foglights don't work....any suggestions?
Setup is JDM OEM Civic foglights ....
Thanks
EDIT: PROBLEM SOLVED =]
Modified by christhereefer at 6:27 PM 10/16/2005
Old Oct 14, 2005 | 05:49 PM
pdiggitydogg's Avatar
simple fuse?
Old Oct 14, 2005 | 06:10 PM
Default Re: (pdiggitydogg)
Dumb question, but where is the fuse located?
Old Oct 14, 2005 | 09:17 PM
Default Re: (christhereefer)
Old Oct 14, 2005 | 10:33 PM
92ehatch's Avatar
fuse box under the steering wheel
Old Oct 15, 2005 | 05:01 PM
Default Re: (93egsedan)
OK it isn't the fuse. Also this morning as I kept playing around with the switch, it worked for awhile. Then I tried again a few hours later and it didn't work again. Ground is hooked up fine and the switch turns on and off. Bulbs are also fine.
Any suggestions?
vtek9
Lighting
Dec 20, 2007 02:26 PM
integra_type-S
Aug 27, 2007 12:08 PM
Inextricabledrvr
Apr 24, 2007 06:54 AM
dohc_profile
May 19, 2006 10:01 PM
damarksman
Sep 14, 2001 08:41 AM
