Car won't start, bad ignition?
Well I kept having problems with my car not wanting to start. I naturally first thought it was my battery. Went had it checked, yes it was bad, got a new one. Well it still didn't start sometimes, so I was like ok, much be starter. Took starter, was bad, got new one, cranked up. Few days later it started not wanting to start again.
Well I know its not the starter, I can push/roll start it and it will crank right up every time. It will go for a week or so and start fine everytime. Then all of a sudden it won't. Try a few times and it might start if lucky. If not then a few hours, days whatever later it might crank right up.
Does this sound like the ignition switch going bad? All fuses and everything are good, all good connections.
Thanks, Doug
Thanks, Doug
coil is new also. It does nothing when you try to start. The lights and everything come on and everything works, just won't start. Then all of a sudden it might start after you just keep trying. Last night wouldn't start at all. Then this mourning cranked right up about 6 times in a row with no problems.
my car did that, and it ended up being the button that the clutch pushes in to start the car, i now have a switch to override that switch. But i would check to see when you push n your clutch if its hitting that button.
runitup
21
Dec 26, 2020 05:17 PM
RichEd223
Sep 7, 2008 07:26 PM
