Car takes a few turn overs to start
My car has a few engine problems, like My v-tec solenoid is leaking, i need a valve cover gasket and a cam shaft seal. It also has a vacuum leak. Well When ever i go to start my car i crank it over and it doesn't start and it usually takes like 2-5 cranks to get it started. I was wondering what you guys think is the problem.
it's a 94 gsr by the way
Could a possible cause of this problem be a battery? My battery will die if I don't drive it, but I just jump the sucker since I'm too lazy to buy a new one.
Thats because civics and integras use group 51 batterys. They are **** ant and won't jump a v8. They do work OK for our little cars though. You should get an optima, granted they are $120 but you won't be dissappointed.
Change your battery. And fix those leaks.
SOKDO
Jun 2, 2005 10:33 AM
