B20/vtec Cams?????
Well its time for an upgrade and I have no clue what cams would work the best on my setup!!! Stock b20z bottem end-GSR head-Stock ports-Intake-4-2-1 header-Apex'i WS2 Catback-hi flow cat-310cc injectors-tuned with hondadata.Thats about it. Will upgrade to a blox manifold. What cams would be good for this setup and what kinda cams work well b20/vtec. What kind of power am I looking at with hte cams, also will the cams be to large and make the valves hit the top of the piston. Let me know what works and what doesn't!!!! Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT »</TD></TR><TR><TD CLASS="quote">I wouldnt run anything bigger than itr cams or you will have valve to piston interference</TD></TR></TABLE>
if you use itr cams retard your timing.. if you advance youll probably be sorry
