which cam to choose?
Old Oct 14, 2005 | 02:17 PM
Vroinshk06's Avatar
Default which cam to choose?
I am looking for a cam to run with my stock compression gsr. I have been looking and have found deals on some old skunk stage 1 and 2, buddy club spec III, or blox tuner b, skunk pro 1
setup is currently
toda header
2.5" exhaust
skunk2 manifold
68 mm throttle body
2.5" cat
home made 3" intake
keep in mind these are all on stock compression, im leaning towards the pro1 but they are also the most expensive of the bunch. if im going to get similar gains from all then id obviously go with something cheaper
Old Oct 14, 2005 | 05:52 PM
UncleD's Avatar
Default Re: which cam to choose? (Vroinshk06)
Stick with a used S2S1 or BC3+, the S2 Pro1's are gonna be way too much cam for that motor. You can run both those cams on stock valvetrain assuming you're keeping your stock rev limiter. Awesome header btw
Old Oct 14, 2005 | 10:44 PM
Vroinshk06's Avatar
Default Re: which cam to choose? (clean rice)
thanks for the input, il probably go with the old sk2 stage 1 because i can get them for $200 where the bc are new for $400
anyone else?
Old Oct 15, 2005 | 12:02 AM
Vroinshk06's Avatar
also which would give better gains the bc III or sk2 stage 1
the sk2 has a tad more lift, but the bc with more duration
intake exhaust
Buddy Club Spec III 11.59mm 304 10.71mm 294
Skunk 2 stage1 11.58 mm 252 @ 1mm 10.9 mm 249 @ 1mm
Old Oct 15, 2005 | 12:26 AM
Icey112's Avatar
i have a set of sk2 stage1 for sale $350 shiped i hit 200whp and 139 tq on the dyno with the these cams.
Old Oct 15, 2005 | 12:51 AM
UncleD's Avatar
Default Re: which cam to choose? (Icey112)
^^ The S2S1 IMO is an awesome camshaft. They can produce very dood numbers with little modification. The BC's are good also, but I would lean towards the S2's for sure
Old Oct 15, 2005 | 01:13 AM
Vroinshk06's Avatar
how many miles are on them? the ones i found for 200 have a ton on them already
Old Oct 17, 2005 | 10:33 PM
Icey112's Avatar
not that much at all i be willing to say they are still very new.
Zero Turbo
Nov 29, 2007 12:54 PM
94DOHCGsr
Nov 9, 2005 03:28 PM
c17r15
Nov 22, 2004 02:42 PM
Replica_Racer
Oct 2, 2003 04:19 PM
AK94GSR
Aug 17, 2003 02:39 AM
