random misfire OBD1 D16y8 READ DETAILS INSIDE!
ok, 1st off its a 95 civic coupe running a 98 d16y8. car misfires randomly. 1st it only did it when it was wet out. so i changed the wires. fixed it for awhile. then is started doing it again when it was wet out. changed the cap, fixed it for awhile. i CANT get the rotor off. the screw is stripped, but it looks like its in good condition. now, heres the funky part. im running uberdata with 450cc injectors and a resistor box. the car is NA right now. the map that i have is a d16y8 basemap by xenocron (he knows his ****, dont try to tell me its the tune, cause it was fine for the first couple weeks with the uberdata in there) its a chipped P06 with vtec. after the car misfired for awhile, it will throw a code 9 (cyl pos sensor) but that has to be because the car is missing. usually when i beat the snot out of it, it wont miss, but sometimes it still does. wires are new, plugs are new cap is new. problem is, the distributor that i have on there is an OBD1 GSR with one ear cut off. i got the motor from a parts car i bought and didnt realize this until about a month after i put the motor in. any suggestions??
and the injectors were sent out, cleaned and flow tested about 2 months before i got them, and they have never had anything but 93 octane flowing through them since. please help, i think it COULD be the dist rotor, but it looks to be in perfect shape. HELP
Brett
Brett
qpzm12
19
Nov 4, 2010 08:56 PM
6doorsentra
Sep 10, 2006 11:49 AM
pearl
Apr 16, 2006 07:26 PM
