d16y8 in 92 civic hatch sputters when accelerating
Old 11-02-2010, 10:36 PM
qpzm12's Avatar
Icon2 d16y8 in 92 civic hatch sputters when accelerating
have a d16y8 in a 92 civic hb ... when i take off either fast or slow the car will sputter like if your gassing the pedal in and out only sometimes though... i have new clutch new throughout bearing... d16y8 ex tranny if it matters.. have tried different ecu's... idk where to start.. what can cause this sputter? and once again it doesnt happen in specific rpm's or specific gears...
Old 11-03-2010, 01:22 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: d16y8 in 92 civic hatch sputters when accelerating
Any check engine lights? What ECU's did you try? Has it done it since you swapped it or just recently? Any regular maintenance done (plugs, wires, etc)? What distributor are you using?
Old 11-03-2010, 09:12 AM
qpzm12's Avatar
im using my b7 dizzy because i kept the motor obd1 and all regular maintenance has been done and it has done it since swapped in about # weeks ago
Old 11-03-2010, 09:49 AM
JENNY_EG6's Avatar
Does it sputter at idle too? or only during acceleration or while taking off? Sounds like you have air in the cooling system or sensors needs some cleaning
Old 11-03-2010, 09:50 AM
JENNY_EG6's Avatar
and you do know there's a difference between a vtec and non vtec dizzy right?
Old 11-03-2010, 10:05 AM
Seagull Management
94EG8's Avatar
Y7 and Y8 distributors are identical, right down to the part number. D15B7 is exactly the same as well except for the OBD1 plugs.
Old 11-03-2010, 10:16 AM
JENNY_EG6's Avatar
I know they have the same part #,and I know it'll make the car run. I owned one before and there's a difference using a Vtec and a Non-V dizzy. In fact, you can try one yourself put a non-v dizzy on your car and run it.... Anyways... I wouldn't put a chicken's head on a duck... as well as a dizzy I'd use the dizzy that the motor came with...
Old 11-03-2010, 10:29 AM
ef9ridda's Avatar
id say you have air in your system, had the same problem in a 91 with a mini me setup
Old 11-03-2010, 11:21 AM
Seagull Management
94EG8's Avatar
Again theres no difference in this case, none. I've pulled apart and built more hybrid distributors than probably any other person on H-T. Z6/Z1/D15B Vtec distributors have a different mounting flange and possibly slightly different timing. But Y7/Y8 are 100% identical, again right down to the part number which you've already admitted, if the part number is the same, they're the same, thats whole point of the part number. D15B7 is different only in terms of having OBD1 plugs, its internally identical physically and electrically to a Y7/Y8 distributor. The whole reason you run a D15B7 distributor in this case because it both bolts up and plugs in.
Old 11-03-2010, 11:41 AM
Dizzzle's Avatar
This is happening to my buddys EG hatch z6 and doesn't have vtec wired up. Wondering what the dealio is.
Old 11-03-2010, 05:08 PM
qpzm12's Avatar
is it maybe because vtec isnt wired ??? and yeah ive been told that there is a difference in the dizzys but it shouldnt matter...??? it bolts up and runs what negatives can a non v dizzy so on a vtec motor??? and it only sputters when i try taking off like while accelerating... whats it mean if i have air in the system??
Old 11-03-2010, 05:27 PM
Seagull Management
94EG8's Avatar
Again, I don't know how many times I have to say this, in this case there is no difference in distributors. If it was a Z6/Z1/D15B Vtec it would matter because the mounting flange is a little different and you can't properly set the ignition timing, in your case no difference at all. If vtec isn't wored you'll throw a CEL for vtec solenoid and vtec pressure switch. Btw, what ECU? If its a P28 you'll have to chip it to get to run right, timing is different between a Y8 and Z6.
Old 11-04-2010, 03:11 PM
ef9ridda's Avatar
94EG8 i dont think they understand.... lol
Old 11-04-2010, 04:47 PM
Seagull Management
94EG8's Avatar
Which part did you want clarified?
Old 11-04-2010, 07:43 PM
qpzm12's Avatar
haha it doesnt throw a code at me for not having vtec wired because i do not have a vtec wiring harness
Old 11-04-2010, 07:50 PM
Seagull Management
94EG8's Avatar
If vtec isn't hooked up it should be throwing vtec codes.
Old 11-04-2010, 07:52 PM
qpzm12's Avatar
if vtec isnt hooked up and you have a non vtec wiring harness it will throw no codes it will show as if you have a non vtec motor
Old 11-04-2010, 08:23 PM
Seagull Management
94EG8's Avatar
This does not work the way you think it does. Vtec ECU will look for vtec solenoid (and in most cases a vtec pressure switch) period, it doesn't matter what you have for a harness, if vtec isn't hooked up and you aren't getting vtec codes you either don't have a vtec ECU or its been chipped with a non vtec program. What ECU are you running?
Old 11-04-2010, 08:49 PM
qpzm12's Avatar
how is my car going to know if it has a vtec motor if it has a non vtec ecu or no vtec harnesS??? hav p28 for when i do wire vtec
Old 11-04-2010, 08:56 PM
mr2passat801's Avatar
If you have an non vtec ecu and harness, and the motor is vtec and its not wired up, it will not throw a code. But if you have a vtec ecu and a non wiring harness, it will throw a code. Or if you have a vtec ecu and harness and its just not plugged in for whatever reason, it will throw a code...
Also, your sputtering could be tons of things. Plugged fuel filter. Going bad fuel pump/regulator. misfire! detonation. Many many things. And since I am assuming you dont have the knowledge or tools to check all this stuff. You might just have to borrow and try a bunch of different parts.
BIG RICH
15
04-16-2012 07:16 PM
qpzm12
10-03-2010 12:08 PM
DA9tegra
06-15-2007 11:27 AM
Quick Reply: d16y8 in 92 civic hatch sputters when accelerating
