What arp headstuds for b17a1?!?!? I can only find them for the b18 and b16!
Old Oct 14, 2005 | 11:27 AM
turbotime's Avatar
Default What arp headstuds for b17a1?!?!? I can only find them for the b18 and b16!
I am trying to buy ARP HEADSTUDS for my b17a1 from http://www.summitracing.com but they only offer headstuds for either b18 or b16 engine. I know the b17 is some weird frankenstein of the two sorta....
So what headstuds do i need the b17a1??
Thanks
Old Oct 14, 2005 | 11:45 AM
Kendall's Avatar
A B17 is nothing but a stroked B16 and therefore uses the same headstuds as the B16.
Nissan SR20 headstuds work as well.
Old Oct 14, 2005 | 11:48 AM
turbotime's Avatar
sweet yeah i know its the same as a b16 but i didint know if it was EXACTLY the same.
ALso when i go to the 92 gsr on summitracing.com it comes up with b18a1 arp studs so i was confused
Old Oct 14, 2005 | 11:55 AM
turbotime's Avatar
so does it use a b16 headgasket?
Old Oct 14, 2005 | 11:59 AM
nickG's Avatar
Default Re: (turbotime)
you should be able get a HG for a b17...but theres no reason a b16 HG wouldnt work..same bore..
Old Oct 14, 2005 | 12:03 PM
turbotime's Avatar
do you know if an oem headgasket will work with an oringed block? and is a b17 head diff from a b16? if so wouldnt that cause headgasket issues?
Old Oct 14, 2005 | 12:59 PM
turbotime's Avatar
trying to order this stuff today...
can i use an oem hg on a oringed block?
Old Oct 14, 2005 | 01:12 PM
Kendall's Avatar
The B17 head is exactly the same as the B16 head. The B17 block is exactly the same as the B16 block. The only differences between the two motors are the cams and the rotating assembly. Therefore when you order parts for your B17, any b16 parts will work.
Old Oct 14, 2005 | 01:14 PM
turbotime's Avatar
awesome
one more question- will an oem headgasket work with an oringed block?
Old Oct 14, 2005 | 02:56 PM
nickG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote"> an oringed block?</TD></TR></TABLE>
wtf is that???
Old Oct 14, 2005 | 03:07 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">awesome
one more question- will an oem headgasket work with an oringed block?</TD></TR></TABLE>
sleeved blocks get o-rings in the top of the sleeve to help with the head gasket seal.
id say check with the company that sleeved your block
Old Oct 14, 2005 | 04:01 PM
turbotime's Avatar
heres the issue, i have no idea who sleeved it, i bought the engine built and have no way of contacting the previous owner.
So with that in mind, should an OEM headgasket work with an origned block? Right now it has a copper headgasket, i have no idea how thick it is...
Old Oct 14, 2005 | 05:56 PM
turbotime's Avatar
quickup
Old Oct 14, 2005 | 10:26 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">heres the issue, i have no idea who sleeved it, i bought the engine built and have no way of contacting the previous owner.
So with that in mind, should an OEM headgasket work with an origned block? Right now it has a copper headgasket, i have no idea how thick it is...</TD></TR></TABLE>
dunno, then id say contact golden eagle mfg ...they are on her and see what he says
Old Oct 14, 2005 | 10:35 PM
Sack Master's Avatar
Default Re: (projectTeG)
You'll have to run the o-rings either way. With that, I have a feeling if you have alot of cylinder pressure, than using an oe gasket probably wouldn't last very long at all. Question, why not use copper gasket? They are stronger anyways.
Old Oct 15, 2005 | 07:39 AM
turbotime's Avatar
i would use a copper gasket but i dont know what thickness or bore i need....
Whats a good generic thickness?
Old Oct 15, 2005 | 07:43 AM
turbotime's Avatar
my engine is 8.5:1CR, and i think its the stock bore (will be able to tell better once i pull the head).
Anyway i actually would like to raise the compression a little is possible. What thickness headgasket do you think i should run to bring the compression up just a bit to like 8.8 or something?
Old Oct 15, 2005 | 07:53 AM
turbotime's Avatar
what do you guys think of
SCE Pro Copper Head Gaskets
sold on summitracing.com? I was thinking of getting a b16 .043 compressed one...
Also what is the function of oringed headgaskets? If my block is oringed should i NOT use an oringed headgasket?
Old Oct 15, 2005 | 08:32 AM
SCE makes excellent gaskets. As for thickness you are just gonna have to measure the one you have.
The function of an o-ring is to make a combustion seal. To prevent the head gasket from blowing out. All copper head gaskets require an o-ring with the exception of the SCE titan ICS gasket. Which you don't want to use.
You have to run o-rings. No head gasket that I am aware of made for hondas comes with o-rings though.
Old Oct 15, 2005 | 08:58 AM
turbotime's Avatar
i have found a few copper headgasket that include orings.
Im saying my BLOCK has orings machined into it, so do i need to use a oringed copper headgasket?
Also you say the SCE are good copper headgaskets? How do i measure the thickness of my current gasket? is tehre a special tol?
Old Oct 15, 2005 | 07:18 PM
Actually the block does not have o-rings machined into it. It has o-ring groves machined into it. You need to supply the o-rings. Which are easy to find. And you said you found a gasket anyways that comes with the o-rings.. So you're in. You can re-use your o-rings too if they aren't all fuckered up. Stainless doesn't compress like copper. I'm under the impression you don't quite understand how o-rings work. You should probably be talking to a shop about doing this for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">How do i measure the thickness of my current gasket? is tehre a special tol?</TD></TR></TABLE>There is a special tool. It's called a micrometer. You measure crushed thickness. Meaning you can mic it out right when you pull off your head.
Old Oct 15, 2005 | 08:55 PM
turbotime's Avatar
yeah i just wasnt clear on the concepts of orings...
So if i can get a copper head gasket and orings (firerings) built in, that will work?
Im not even sure if its my headgasket thats toast, the head just may be lifting, im gonna try arp studs first i think
Old Oct 16, 2005 | 12:43 AM
The only problem I can think of having a headgasket that has a built in o-ring, is that what if the o-ring doesn't line up with your block(even though thats probably not gonna happen because there is no room to work with there anyways), or even worse it's set up for an o-ringed head.
zlambe
Jul 13, 2012 06:04 AM
Turpid Porpoise
Nov 21, 2011 02:55 AM
boostedteggy
Oct 21, 2009 03:20 PM
dtenakoun
Feb 19, 2009 10:23 PM
showtymers619
Apr 30, 2004 03:11 AM
