The starting problem with my Integra has returned, help please.
Old Oct 14, 2005 | 09:45 AM
RuskeR's Avatar
Default The starting problem with my Integra has returned, help please.
Just out of the blue my Integra doesn't start. The engine cranks over fine, but that is all I get. I checked the spark plugs and everything seems fine. The last time this happened I changed the plugs, and dist. cap and she started up. I figured the plugs might have been too old and new plugs fixed the problem. Even though I'd imagine I'd see some signs of the plugs going bad.
The only thing I can figure right now is to start checking the fuel system. I do hear the fuel pump turn on before I try to start the car, so I'm assuming that is okay. My next step I'm guessing is to change the fuel filter and see what that does.
How often does the fuel press. reg. fail? Is it possible this is the problem?
How much does a descent fuel press tester cost? I really don't know much about fuel system.
Any input is welcomed.. I need to get her running again because my 240 isn't finished yet.
Fixed!
https://honda-tech.com/zerothread?id=1431468
Modified by RuskeR at 8:35 PM 7/10/2007
Old Oct 14, 2005 | 11:11 AM
WhiteTegSE's Avatar
Default Re: The starting problem with my Integra has returned, help please. (RuskeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuskeR &raquo;</TD></TR><TR><TD CLASS="quote">
I checked the spark plugs and everything seems fine. </TD></TR></TABLE>
Did u just visually look at them?
Or did you pull one and ground it and have someone crank the car over to see if it is actually firing??
Old Oct 14, 2005 | 12:03 PM
92db2's Avatar
yeah if check to see if your gettin spark by doing what was just mentioned and if your not getting anything it could be your coil inside the dizzy.
Old Oct 14, 2005 | 12:05 PM
RuskeR's Avatar
For now I just visually looked at them. I thought maybe I had flooded the car the last time I shut it down, and tried starting it a few too many times, so I have it on a charger right now. The last time this happened the plugs were past due for a replacement, but I did test them to see if they infact were firing and they were.
I'm guessing it's not getting fuel somehow..
Old Oct 14, 2005 | 06:27 PM
Sam92Teg's Avatar
Default Re: (RuskeR)
Main Fuel Relay
Old Oct 14, 2005 | 09:50 PM
RuskeR's Avatar
Would the main fuse relay be something that could work for 6 months, then act up for awhile? I'll check it though
Old Oct 15, 2005 | 04:39 AM
LSracing94's Avatar
if you hear your fuel pump comming on then its most likely not a problem with your main relay. It is most likely your coil or something to do with the dizzy. Check for spark before you go out buying things.
Old Oct 15, 2005 | 08:41 AM
sykotic's Avatar
Default Re: (LSracing94)
just start with the basics, make sure you're getting spark, pull a plug wire off a plug and stick a screw driver in, lay it down and crank and see if it sparks. Then check for fuel, can do that many different ways... check and see which isnt getting to the cylinder, if you're getting both then more then likely its your plugs...
Old Oct 18, 2005 | 10:24 AM
RuskeR's Avatar
I'm going to change the fuel filter and see if that has any effect. I doubt it will seeing as the car ran fine the night before. It's due for one anyways...
Old Oct 21, 2005 | 10:16 PM
RuskeR's Avatar
Update:
Well I figured it was something with the ignition system.. when I took off the rotor, it was looong gone. I think it was a little early to replce, but anyways.. slapped on a new one and she started right up.
Old Oct 24, 2005 | 03:03 PM
HEAVY.HITS's Avatar
i have the same problem...HELP ME
J-SpecRacing
Mar 9, 2008 03:58 PM
Project_Civic
Apr 3, 2005 05:07 PM
phreakmang
Jul 26, 2004 06:01 AM
moridin2004
Feb 2, 2004 02:48 PM
APEX i GSR
12
Dec 10, 2002 08:32 PM
