i just bought an ef and have a wrecked ej1
Old Oct 14, 2005 | 08:14 AM
djxtc65's Avatar
Default i just bought an ef and have a wrecked ej1 what can i use
what can i swap over the the ef i have all the strut bars from my 95 coupe and what aboout my brake ihave brand new drilled and slotted rotors on my coupe i hope i can use some of this stuff
also the car has a zc sohc swap and my 95 ex has the same motor but he said he never wired up the vtec so what do i need from my coupe to get it orking
thanks for all the help
what i wrecked
what i bought
Modified by djxtc65 at 5:24 PM 10/14/2005
Modified by djxtc65 at 6:01 PM 10/14/2005
Old Oct 14, 2005 | 09:01 AM
djxtc65's Avatar
Default Re: i just bought an ef and have a wrecked ej1 what can i use (djxtc65)
bump
Old Oct 14, 2005 | 10:29 AM
Chase's Avatar
If you have a sohc zc then its non vtec. Get your cylinder head from your ex and put it on the zc. Its called a mini-me, and with those zc pistons it should be nice . Make sure to run premium fuel tho.
Search mini me and you'll find some **** on how to do it.
Old Oct 14, 2005 | 11:15 AM
djxtc65's Avatar
Default Re: i just bought an ef and have a wrecked ej1 what can i use (b16crxkid)
maybe i red it wrong but it has a vtec sohc in it now its just not wired up
Old Oct 14, 2005 | 08:32 PM
djxtc65's Avatar
what about my strut bars will they fit
Old Oct 14, 2005 | 08:56 PM
Contender25
Guest
Posts: n/a
Idk don't know about some of that stuff, you can see but if it doesn't then sell the parts for money to get new parts for you're hatch now. Do you still got those stocky 13's?, i would hella use those on the hatch and with a drop would look sick. Looks good btw, i also noticed a little crx poppin up in the background, do you own that too? or you're neighbor?.
Old Oct 14, 2005 | 08:57 PM
Contender25
Guest
Posts: n/a
Btw how did you wreck the coupe?.
Old Oct 14, 2005 | 09:22 PM
e jay one's Avatar
Default Re: (Contender25)
the strut bars will fit. what you should do is convert the motor in the hatch to obd1 since you can use the dizzy and ecu from the coupe. im sure you could swap out the whole spindles from the coupe and have bigger brakes but youll probably need the coupe axles.
Old Oct 14, 2005 | 11:20 PM
djxtc65's Avatar
Default Re: (e jay one)
from what i understand the hatch has the same motor as my coupe but it just has not been wired to obd1 so ill have to do that but i dont know how
as for the braked is that hard cause want to use the rotra brake set up i have they were great on my coupe
and i have gsr blades im going to put on it and slam it it should look prety hot if you ask me plus im going to do the body work and its going to be flat black till after the winter than ill get it sprayed black again
and as for my coupe i fell asleep and ran a red light and hit a big yellow bus
Old Oct 14, 2005 | 11:48 PM
Contender25
Guest
Posts: n/a
I would not get you're self into trouble by trying to rewire all that **** to obd1 when obdo is simpler.
Old Oct 14, 2005 | 11:53 PM
djxtc65's Avatar
but than ill never get the vtec to work right
what if i bought obd0 to obd1 harness would that do anything
thanks
Old Oct 15, 2005 | 02:11 PM
Chase's Avatar
Default Re: (djxtc65)
http://www.rywire.com
Old Oct 15, 2005 | 02:12 PM
Chase's Avatar
Default Re: (b16crxkid)
dont paint it with spray paint just maybe paint the top and get a CF hood or sumthin. Just buff all the other paint. Flat black looks ghetto, unless u do it right.
Old Oct 15, 2005 | 03:16 PM
solfly's Avatar
see what engine code you have on both cars
Big Boi B
Feb 25, 2013 10:31 PM
[Ennis_D]
Southeast (Sales)
Jan 12, 2011 07:16 AM
douglaslovin
Jul 27, 2008 12:44 PM
Didly
Feb 23, 2006 08:31 PM
