Valves ticking (valve adjustment didn't help)
Old Oct 14, 2005 | 08:03 AM
t3hatch's Avatar
Default Valves ticking (valve adjustment didn't help)
Asking for anyones knowledge. My b20 has been noisy for a while(head noise), so I did a valve adjustment and put them back to honda specs. Before the adjustment, most the valves were loose by .001 or less. So after the adjustment, the same noise is coming from the head still. Is my next step to tighten them a little more past honda specs. Thanks in advance.
Old Oct 14, 2005 | 08:32 AM
gsrious's Avatar
i would think that they are just the injectors that are thicking...
Old Oct 14, 2005 | 08:44 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (gsrious)
I have a natural tick to my LSVTEC, always have. Valve lash is good, LMAs are new.
Old Oct 14, 2005 | 08:45 AM
t3hatch's Avatar
No, its much louder than injector ticking.
Old Oct 15, 2005 | 10:03 AM
t3hatch's Avatar
Default Re: Valves ticking (t3hatch)
anyone else?
Old Oct 15, 2005 | 10:31 AM
davelux's Avatar
Have you checked the Valve Springs? If they are worn out, they may not pull on the valves enough to keep them in contact w/the camshaft through the full duration of the stroke.
Also, maybe rockerarms are coming into contact with the head. Make sure valve seats are all in spec as well.
From what I have heard, you don't want to go any stricter than the clearence suggested by Honda. Last thing you want is a valve fused to the guide just waiting for the piston to smack it. That will ruin your day.
Old Oct 15, 2005 | 02:13 PM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3hatch &raquo;</TD></TR><TR><TD CLASS="quote">Asking for anyones knowledge. My b20 has been noisy for a while(head noise), so I did a valve adjustment and put them back to honda specs. Before the adjustment, most the valves were loose by .001 or less. So after the adjustment, the same noise is coming from the head still. Is my next step to tighten them a little more past honda specs. Thanks in advance.</TD></TR></TABLE>
Do not go tighter than hondas specs, you probably have a dead lma
Old Oct 15, 2005 | 04:06 PM
I Have an STD's Avatar
wrenchin'
Default Re: Valves ticking (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">
Do not go tighter than hondas specs, you probably have a dead lma</TD></TR></TABLE>
hey asshat, he MIGHT have meantioned that it was a B20. soooo yer pretty wrong. non-vtec = no LMAs. i think thats its probably a collapsed valve spring. happened to a buddy of mine
Brett
Old Oct 15, 2005 | 04:42 PM
NJIN BUILDR's Avatar
Default Re: Valves ticking (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">
Brett</TD></TR></TABLE>
Now thats the way we respond on HT.How far is Albany from Geneseo anyway?
Glenn
Old Oct 15, 2005 | 04:49 PM
t3hatch's Avatar
Default Re: Valves ticking (davelux)
Thanks everyone, I'll check the springs out, never thought of it, but I'm going to bet that your right with the springs.
ketchup
Nov 29, 2010 10:20 PM
acurateg96
Feb 6, 2006 03:24 AM
GSRVTEC1
Oct 31, 2005 01:19 PM
FitCRX
Jan 12, 2003 07:23 AM
