Limited slip
Old Oct 14, 2005 | 06:04 AM
H2Os's Avatar
Default Limited slip
Hi, I am a 2001 Accord owner. I am doing a H22 swap. I am sleeving with Darton sleeves, installing 9:1 JE Pistons and installing oversize valves, cams, springs, etc..pretty much building a drag engine. I am running a Garret GT30R turbo with other goodies. I am trying to get close to 450-500 whp! I need a little advice on what kind of limited slip and axels to have to handle that kind of power! Thank you for your time!
Old Oct 14, 2005 | 09:58 AM
notoriousB's Avatar
Default Re: Limited slip (H2Os)
there isn't a whole lot for the 6th gen chassis, however you could use an H22 transmission with OEM LSD, or both quaife and OBX make LSD units that will fit the H-series transmission. (I recommend quaife!)
fienza (fidenza? spelling's probably wrong) makes axles for the F23 at like $260 each - you'll want to use accord axles for the swap.
HTH
Old Oct 14, 2005 | 11:47 AM
H2Os's Avatar
Default Re: Limited slip (notoriousB)
Thank you for your time and your research...I will look into those!
Old Oct 14, 2005 | 12:18 PM
YeuEmMaiMai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">there isn't a whole lot for the 6th gen chassis, however you could use an H22 transmission with OEM LSD, or both quaife and OBX make LSD units that will fit the H-series transmission. (I recommend quaife!)
HTH</TD></TR></TABLE>
what he said
Davi_Vtec
Jan 6, 2012 01:40 PM
RPM JDM
Nov 12, 2009 06:42 PM
silentvoice19
Jul 31, 2006 07:46 PM
JDM_Ej
Dec 22, 2005 03:16 AM
JSR
Aug 27, 2004 11:28 AM
