90 accord tranny filter/screen
Old Oct 14, 2005 | 02:51 AM
zx9rbart's Avatar
Default 90 accord tranny filter/screen
I've read numerous times on here about a filter or screen in the auto trans. Can someone tell me where it is and if there is anything special that needs to be done to clean it...thanks.
Old Oct 14, 2005 | 05:11 AM
deserthonda's Avatar
Default Re: 90 accord tranny filter/screen (zx9rbart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zx9rbart &raquo;</TD></TR><TR><TD CLASS="quote">I've read numerous times on here about a filter or screen in the auto trans. Can someone tell me where it is and if there is anything special that needs to be done to clean it...thanks.</TD></TR></TABLE>
the filter ( screen ) u r talking about is the 1 for the lock up and shift solenoids....we advice to remove and clean when tranny has certain problems
there is no servicable filter in auto tranny, there is a filter but to ge to it u got to disassamble the tranny totally it is located below the valve body inside the tranny ...
Old Oct 14, 2005 | 06:12 AM
jokestar's Avatar
Default Re: 90 accord tranny filter/screen (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">
there is no servicable filter in auto tranny, there is a filter but to ge to it u got to disassamble the tranny totally it is located below the valve body inside the tranny ...</TD></TR></TABLE>
like what kind of certain problems? slippy shifting? TY in advance
Old Oct 14, 2005 | 06:19 AM
P_Adams's Avatar
Default Re: 90 accord tranny filter/screen (jokestar)
When it becomes partially blocked, it can show up as slow / delayed shifts and inoperative Torque Converter lock-up. Electrical failure of these same solenoids will set a TCM code and the D4 lamp will Flash.
P
Old Oct 14, 2005 | 07:15 AM
zx9rbart's Avatar
Default Re: 90 accord tranny filter/screen (P_Adams)
so where is this screen, or is that what you are saying is below the valve body. Mine dosent like to lock up the converter unless it is a hot day. I want to check this screen but cant find it.
Old Oct 14, 2005 | 09:28 AM
P_Adams's Avatar
refer to this illustration for the solenoid and base filter detail (#6 and #8):
http://www.hondaautomotivepart...USING
Ans a second circular filter in the secondary valve body (#30):
http://www.hondaautomotivepart...+BODY
P
Old Oct 14, 2005 | 07:42 PM
zx9rbart's Avatar
so it appears that if you remove bolts 9 and 19 you can get to these screens. Is this correct? BTW thanks
Old Oct 14, 2005 | 08:07 PM
P_Adams's Avatar
Yes, Indeed!! "dems the culprits
P
Old Oct 14, 2005 | 09:22 PM
zx9rbart's Avatar
thank you
De_tour
May 15, 2006 02:59 PM
1990AccordEX
Nov 27, 2005 11:38 PM
boltnut
Jan 11, 2005 07:27 PM
89JDMcrx
Oct 13, 2004 03:33 PM
fe519
Nov 26, 2003 07:56 PM
