Whats the best head?
Old Oct 14, 2005 | 01:02 AM
CRXual's Avatar
Default Whats the best head?
I have a D15B and I was wandering what the best preformance head is that I can use and what else needs to be changed to make it work?
currently there is nothing wrong with the head that I have I just want to get an Idea what combos are out there and what will produce the best results.
thanks
Mike
Old Oct 14, 2005 | 01:58 AM
hellshock2182's Avatar
Default Re: Whats the best head? (CRXual)
d16z6 head with some port an polish work done, Aftermarket cams like a zex 59300 and a good valvetrain. you'll be golden
Old Oct 14, 2005 | 06:04 AM
HondaFerris's Avatar
Default Re: Whats the best head? (hellshock2182)
best head....well this one time after my junior prom i got....oh you mean whats the best head swap for your car...lol yes i agree with the above post.
Old Oct 14, 2005 | 06:11 AM
djsire's Avatar
Default Re: Whats the best head? (HondaFerris)
so the z6 is better than the y8? i thought the mini me was easier to do with a y8?
Old Oct 14, 2005 | 06:28 AM
crxluv2's Avatar
when they use their teeth
Z6
Old Oct 14, 2005 | 11:09 AM
CRXual's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXual &raquo;</TD></TR><TR><TD CLASS="quote">I have a D15B and I was wandering what the best preformance head is that I can use and what else needs to be changed to make it work?
thanks
Mike</TD></TR></TABLE>
Thanks, that is just what I will be looking for now
Old Oct 14, 2005 | 11:14 AM
Mach69's Avatar
Default Re: Whats the best head? (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">so the z6 is better than the y8? i thought the mini me was easier to do with a y8?</TD></TR></TABLE>
The Z6 head is better than the Y8 head. Why would it be easier to do a Y8 mini-me? Its just about the same. Except you have different heads, different obds. Mini-me with a Y8 is just as easy as it is with a Z6 head. The Z6 head outflows the Y8 head. The Y8 head will produce a higher compression ratio.
However, if you were to have the exact same D15B engine, with the exact same compression ratio etc, and the only difference was the head, I believe the Z6 head would make more power. Probably less than a 0.1 horsepower difference though.
Old Oct 14, 2005 | 11:17 AM
davens's Avatar
Personally, I think its best to choose the head based on your OBD plans.
If you plan to stay with obd-0, get the y8...the d16a6 distributor will bolt right up.
If you plan to go with obd-1, get the z6 so the d16z6 distributor bolts right on.
People will split hairs between the two performance wise, but the differences are really very minor. At the end of the day, they both produce roughly the same hp.
Old Oct 14, 2005 | 04:39 PM
CRXual's Avatar
Default Re: (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">Personally, I think its best to choose the head based on your OBD plans.
People will split hairs between the two performance wise, but the differences are really very minor. At the end of the day, they both produce roughly the same hp.</TD></TR></TABLE>
Yes I plan to go ODB-1 only because I am going Phearable unless I deside to use my computer and electronics skills and make my own pooter systems. Donno yet, still kicking it around but if the D16Z6 is makes only 0.1 hp difference, then I will take the 0.1
Old Oct 14, 2005 | 04:50 PM
CRXBart's Avatar
Default Re: (CRXual)
Use a z6 w/y8 intake mani. Thats what I got on my beater. I got the Z6 block too though. I'm running OBD1 also. I like it allot. Seems to run allot smoother than my old OBD0 cars.
fq200turbo
Apr 21, 2008 05:40 PM
92ehatch
Jul 21, 2005 11:43 AM
93formula
May 13, 2005 05:52 PM
poetter
Oct 23, 2004 11:43 AM
Vinceg99
Sep 12, 2003 12:57 PM
