Block Girdle on ITR's?
Old Oct 13, 2005 | 08:09 PM
itr1244's Avatar
Default Block Girdle on ITR's?
my motor is getting rebuilt in short future and i have a question
i know b18c5's come with one but is it worth it to get aftermarket ones?
motor will be 12:1 compression. 9K redline. not sure what's the fuel cut.
thanks in advance
Old Oct 13, 2005 | 08:42 PM
Anthonyl469's Avatar
Default Re: Block Girdle on ITR's? (itr1244)
No need for a new one, stock is great.
Old Oct 14, 2005 | 05:54 AM
B18C Turbo's Avatar
yep they are the same. If you are using an LS or B20 block then I would say yes get an aftermarket one. They are wicked nice and run about $135 on ebay, you need a GSR/ITR windage tray and Oil pickup.
Old Oct 14, 2005 | 07:26 AM
KayOs's Avatar
drastic increase in horsepower will dictate a need to upgrade to a better block girdle. If that's the case, then I would recommend a z10, otherwise as has been mentioned above, keep it stock.
Old Oct 14, 2005 | 07:41 AM
Bradstard's Avatar
I'm running the stock one without any problems so far.
Old Oct 16, 2005 | 03:18 AM
itr1244's Avatar
Default Re: Block Girdle on ITR's? (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">I'm running the stock one without any problems so far. </TD></TR></TABLE>
ok. if you are running good with stock.. i would be ok too i asume..
KiNG $h!t
49
Jan 7, 2008 04:39 PM
DA_JDM
Apr 2, 2007 05:42 PM
CRX 2.0V-T
Mar 3, 2007 11:51 PM
hybrid92b20
Oct 21, 2004 02:17 PM
vtecb20coupe
Jan 29, 2004 12:23 AM
