D15B block D16y8 head PROBLEM HELP!!!!!!!!!!!!!
Old Oct 13, 2005 | 04:03 PM
THC07's Avatar
Default D15B block D16y8 head PROBLEM HELP!!!!!!!!!!!!!
When i put the d16y8 head on a d15b block i cant figure out which distrubutor to use. the d15b has CPS in distubutor, with the y8 distrubutor it dose not. but you cant put a d15b distrubutor on a y8 head, what should i do. do i have to have the CPS hooked up? (Crank Postion Sensor)
Old Oct 13, 2005 | 06:21 PM
rainforest's Avatar
Default Re: D15B block D16y8 head PROBLEM HELP!!!!!!!!!!!!! (THC1107)
use what ever distributor matches to the exu you are using. and you can modify ehr disb to make it fit
Old Oct 14, 2005 | 06:02 AM
Mista Bone's Avatar
D Tranny Guru
92-95 DX/CX dist...........
What year is the car?
Old Oct 14, 2005 | 06:41 AM
THC07's Avatar
Default Re: D15B block D16y8 head PROBLEM HELP!!!!!!!!!!!!! (Mista Bone)
it is a 97. i swaped in a 95 d15b. will the car run without a crank sensor?
Old Oct 14, 2005 | 10:55 AM
Mista Bone's Avatar
D Tranny Guru
do the workaround at the ECU, but keep your dist...........
Katman or someone posted on here how to get around the crank sensor
Old Oct 14, 2005 | 11:31 AM
THC07's Avatar
Default Re: (Mista Bone)
dO YOU KNOW WHERE THE THREAD IS?
I STILL DONT KNOW HOW TO SEARCH FOR THREADS. KATMAN YOU SAID
Old Oct 14, 2005 | 02:07 PM
Mista Bone's Avatar
D Tranny Guru
https://honda-tech.com/zerothread?id=1029958
theslugbug
May 21, 2008 11:01 AM
97exd16
Feb 15, 2007 09:49 AM
crashtest Sonny
Aug 9, 2003 02:51 PM
