Alarm don't work after recharged battery
Old Mar 5, 2002 | 12:53 PM
SamC's Avatar
Default Alarm don't work after recharged battery
My battery die since I have driven it for a while. I recharged the battery. Now my stock Acura alarm don't work nor does my FX pager works. There are no "beeps" and won't lock the doors. Do I need to reset the system? what should I do? thanks
Old Mar 5, 2002 | 07:23 PM
MugenSi00's Avatar
Default Re: Alarm don't work after recharged battery (SamChan)
more then likely there is a blown fuse somewhere
Old Mar 5, 2002 | 10:54 PM
SamC's Avatar
Default Re: Alarm don't work after recharged battery (MugenSi00)
thanks..I check the fuse later...
Old Mar 13, 2002 | 09:29 AM
SamC's Avatar
Default Re: Alarm don't work after recharged battery (SamC)
I've unplugged the wiring harnless...and it still doesn't work...where do I check the fues?
Old Mar 14, 2002 | 01:31 AM
01TypeR680's Avatar
New User
i know with pager u gotta disconnect and reconnect bat cable w/ someone pressing down hood sensor for that to work properly, does the alarm unit itself have a reset switch???
Old Mar 14, 2002 | 05:50 AM
GSRaCeRbOI's Avatar
try disconnecting all the fuses to the alarm. then plugging them back in.... it could also be that the alarm "forgot" your remote code.. not sure how long the battery was dead then recharged...and you may need to re-program your remote to work w/ the alarm...
JBB93Coupe
14
Jun 16, 2009 02:11 PM
whiteboy-dc4
Audio / Security / Video
Jan 26, 2009 09:19 PM
barefootbilly
15
Jun 3, 2004 01:54 PM
Prod
Jan 13, 2004 01:29 PM
schwinn
Jun 13, 2002 06:56 PM
