rusted fuel lines and brake lines
Old Oct 13, 2005 | 01:46 PM
adam94lude's Avatar
Default rusted fuel lines and brake lines
wtf i went to a shop to do an oil change and i been going there for years every month and all the soden they tell me my lines r rusted front to back i go look at them and they r rusted as hell so question
this is a 5gen accord (95)
are the lines pure metal like do they have a rubber line in them
or am i prety much screwed, its pure metal cuz if it that means the metal till start chiping from inside as well as outside and from inside it will mix with the fuel am i correct ?
anyplaces i can get a kit to save money for new lines at the dealership the lines r 1000$ front to back and i mean they r just lines
Old Oct 13, 2005 | 07:33 PM
slomofo's Avatar
GDD Member
Rust on the outside is ok, lots of people have rusted lines. It won't start rusting on the inside because moisture causes rust, so where there is high pressure gas, there's probably no moisture.
Old Oct 14, 2005 | 07:34 AM
Flashmn's Avatar
Default Re: (slomofo)
It will rust through on the outside though and eventually when the wall thickness gets thin, it will rupture.
Old Oct 15, 2005 | 12:06 PM
adam94lude's Avatar
Default Re: rusted fuel lines and brake lines (adam94lude)
does anyone know of a kit where i can get all the liners front to back it so expensive to get them from the dealer
Old Oct 15, 2005 | 12:11 PM
Flashmn's Avatar
Bend them yourself?
Old Oct 16, 2005 | 03:25 PM
adam94lude's Avatar
i cant bend all of them
Old Oct 16, 2005 | 04:41 PM
BigMoose's Avatar
Is the kilobuck price the parts price, or parts and install?
The reason I ask, it is a real pain to change them all. If you search on it you will find a guy that said the subframe has to come down, and the gas tank down. That the factory bent lines won't really go back in with the engine and everything else still in, even removing the parts I mentioned.
I am still working up the courage to perhaps break the fuel line changing the fuel filter on my kids just bought 1996 Accord. I just tried wrenching it again today, and prudence got the better of me. Decided, "If it 'aint broke, I'm not a gonna break it before winter."
Old Oct 17, 2005 | 07:52 PM
adam94lude's Avatar
i think i might just sell it the parts were like 800$ and then its almost the same to get them put it its alot of work... well not really alot of work just gave to get **** out of the way like the tank but u know how mechanics are. for taking down the tank they will charge u 3 hours labour
Old Oct 18, 2005 | 05:43 AM
JimBlake's Avatar
Default Re: rusted fuel lines and brake lines (BigMoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">... If you search on it you will find a guy that said the subframe has to come down, and the gas tank down...</TD></TR></TABLE>That might be me...
A shop with a lift might not have much trouble lifting the car & then lowering the subframe a few inches. I wasn't gonna be able to do that by myself.
Mine was a '95 Integra 4-door. When I look under our '98 Accord 4-door, it looks like there's enough room between the firewall & steering rack so you can snake the factory lines in thru there. On a Prelude? You gotta get under there & look for yourself.
Maybe the dealer mechanic HAS to do it the factory way. Check independant shops, lots of those guys know how to use bulk steel tube & bend it up to fit.
Old Oct 18, 2005 | 08:09 AM
baphomet's Avatar
Default Re: rusted fuel lines and brake lines (JimBlake)
If they are not broken yet degrease them, use a metal etcher like Metal Ready or Ospho, and then paint the lines with por15 or, if you are poor, Rustoleum brand paint or equivalent. This will stop the rust from spreading.
Old Oct 18, 2005 | 09:10 AM
92HB_HB's Avatar
Default Re: rusted fuel lines and brake lines (baphomet)
i did both of my rear brake lines on my 4dr teg from the porportioning valves all the way to the rear discs.. cost me about $25 i parts.. shouldn't be too hard if you're mechanically inclined or have friends who are..
Old Oct 19, 2005 | 01:37 AM
adam94lude's Avatar
Default Re: rusted fuel lines and brake lines (92HB_HB)
yeah well thats ur rear brake lines... my rears and front brake lines and GAS lines are all rusted to ****.
Old Oct 19, 2005 | 06:15 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adam94lude &raquo;</TD></TR><TR><TD CLASS="quote">yeah well thats ur rear brake lines... my rears and front brake lines and GAS lines are all rusted to ****. </TD></TR></TABLE>At least you know from the beginning that you have to replace ALL of them.
Rear brake (2) & fuel lines (3) run together in the same tray. I went & bought the factory tubes before looking under the car (stupid...). When I realized the clearance problems it was too late.
I would have been better off buying bulk tubing, threading it thru, & THEN bending it into shape. Then using a flaring tool or compression fittings or whatever to make the connections.
Old Oct 20, 2005 | 11:32 AM
sleepystyle's Avatar
what are this bulk tubing should i get them to do all the lines whats the price diffrence with them and factory tubes
Old Oct 20, 2005 | 01:38 PM
JimBlake's Avatar
Default Re: rusted fuel lines and brake lines (ninjaskillz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjaskillz &raquo;</TD></TR><TR><TD CLASS="quote">what are this bulk tubing should i get them to do all the lines whats the price diffrence with them and factory tubes </TD></TR></TABLE>Since I was dumb & didn't do it that way, I don't know...
hmong337
May 18, 2010 06:34 PM
jdmkid8383
Apr 22, 2007 11:34 AM
extro97
Apr 13, 2005 08:35 AM
JimBlake
Feb 4, 2005 03:57 AM
