B18C block w/B16A head
Old Mar 5, 2002 | 12:50 PM
Spartanic's Avatar
Default B18C block w/B16A head
Anybody out there ever done a B18C block w/B16A head conversion with integra or Civic Type R pistons? If so than what was the compression and how much HP did you get?
Old Mar 5, 2002 | 12:56 PM
Spade's Avatar
Default Re: B18C block w/B16A head (Spartanic)
http://www.bojangz.com/calculator/
Old Mar 5, 2002 | 03:58 PM
.nate's Avatar
Default Re: B18C block w/B16A head (Spade)
Ive seen a b16 block with a GSR head... but not the other way around... I think he said that it raised his compression to almost 11:1
Old Mar 5, 2002 | 05:10 PM
fowler!'s Avatar
Default Re: B18C block w/B16A head (TheFLY)
Well, if you put the b16a head on the GSR without switching pistons, you'll actually lower your compression ratio due to the shape of the head's combustion chamber.
Likewise if you put a GSR head on a b16a, you'll raise the compression about .2 pts. I believe.
Basically known as the Poorman's type R motor. If you plan on putting a stock b16a head on a GSR, I wouldn't do it. For about that much you could get a Skunk2 manifold and some other goodies. Now if you're doing an ITR head, that's a different story. Very worth it. Just switch to some CTR or JDM P30 pistons and you'll be good to go
Old Mar 5, 2002 | 05:55 PM
CJ Fabrications's Avatar
Default Re: B18C block w/B16A head (Fowler Yo!)
the b16a head is the same as the type r head except for some factory porting. You can actually make the B16a head better.
douglas_be
Mar 12, 2004 12:36 PM
Run4Me
Dec 8, 2003 07:51 AM
pacienzavtec
Sep 14, 2002 08:32 PM
teger
Apr 12, 2002 03:46 PM
slimbo
Mar 4, 2002 10:02 PM
