Civic LCA's compared to DC
Old Oct 13, 2005 | 12:39 PM
Atheist's Avatar
Default Civic LCA's compared to DC
Is there a difference in size? My cousin has a civic LCA with a sway bar hole, could he run a teg on the other side problem free or would they need to match?
Old Oct 13, 2005 | 12:48 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Civic LCA's compared to DC (Atheist)
Are you sure it's a sway bar hole? The Civic rear LCA's have a small hole in them, but the DC's rear LCA's have the hole that "pops up" on top of the LCA. It's not centered in the middle of it. I'll try to find a picture.
In any case, I'm almost 100% sure you can swap the two.
Old Oct 13, 2005 | 03:09 PM
Mt3c's Avatar
what year civic does your cousin have? i'm hoping you are taking about the 92-95 civics, then yes, he can run the 94-01 rear lca.
if its a 96-00 civic, then no, he can't/shouldn't use the integra lca.
Old Oct 13, 2005 | 03:44 PM
Atheist's Avatar
Default Re: Civic LCA's compared to DC (Mt3c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mt3c &raquo;</TD></TR><TR><TD CLASS="quote">what year civic does your cousin have? i'm hoping you are taking about the 92-95 civics, then yes, he can run the 94-01 rear lca.
if its a 96-00 civic, then no, he can't/shouldn't use the integra lca.</TD></TR></TABLE>
I'm talking about front, and my cousin has an DC right now but has a pile of 93 civic suspension, the driver side of which has a bent LCA.
So no Civic's had a sway bar hole back then? He said they did, but I have not looked.
Old Oct 14, 2005 | 09:53 AM
Atheist's Avatar
anyone?
Old Oct 14, 2005 | 10:14 AM
shamoo's Avatar
Default Re: (Atheist)
Sorry, I was thinking of the rears when I posted. The fronts, unfortunately, I have no idea. Civics did have front sway bar holes in their front ones.
Old Oct 14, 2005 | 03:39 PM
Mt3c's Avatar
Default Re: (shamoo)
I think if the civic is an Si, Ex, Lx, it will have a mount for the front sway bar. I know for a fact though if it is a dx, it will not have a hole for the endlink.
I've installed the front lca from an integra onto a 93 civic, so i will assume that the civic lca will go onto the teg no problem.
also, what year civic is the Front LCA from?
There might be a slight chance that there was a change from the 92-95 to 96-00 civics but I don't know. Best thing to do now is ask the folks in the civic forum about this.
psychobear
Jul 12, 2014 02:48 PM
JDMCRX
12
Oct 17, 2008 08:46 AM
Bury Your Dead
Suspension & Brakes
Dec 26, 2007 05:37 PM
Stunna MIKE
Suspension & Brakes
May 31, 2006 08:55 PM
chris_c
12
Dec 10, 2004 12:29 PM
