94 civic engine in a 92 civic
Will a 1994 civic engine from a stick shift car fit in a 1992 civic stick shift? Will it just bolt in or will I have to change the electronics or something else? How about the transmission. are they the same? thanks Brian
Just swap it in. If the engine is the same it should be an easy swap. If you are going from non-vtec to vtec, you will need the proper ecu and wiring harness or modify your existing harness.
Re: (civexturbo)
same wiring harness will work you would just have to run 3 wires off your VTEC solinoid, two to the new ECU (you will need the VTEC ECU) and one wire is a ground.
Re: 94 civic engine in a 92 civic (drtyhatch)
I did a search but am not up on all the abreviations and what they mean. Thank you for the reply and I will try to learn more . Brian
Nisif
Honda Civic (2001 - 2005)
05-30-2017 11:24 AM
aznwash3wboi
12-22-2008 02:23 PM
joestud
09-27-2003 03:37 PM
