how does the VIAC works ?
Old Oct 13, 2005 | 12:35 AM
sleepystyle's Avatar
Default how does the VIAC works ?
the two nipples coming out of it are on a plate.. i took the plate off and behind the plate issss nothing nothing just some space so wats teh point of having those nipples on ? when they dont even connect to anythin inside the viac
Old Oct 13, 2005 | 07:14 AM
jmcclell's Avatar
Default Re: how does the VIAC works ? (h22accordking)
Coolant passes over the back of the IAC valve to heat it. This helps a smoother idle in cold weather.
The previous owner may of disconnected the coolant hoses to help reduce the air intake temperature. It is a common modification to Hondas.
Old Oct 14, 2005 | 01:10 AM
ohhhhhhh really eh coo thanks last questions ok so now i know how the hose connects in it... but wat about the other size where there r two holes one has a filter how do they work
Old Oct 14, 2005 | 02:46 AM
jmcclell's Avatar
The IAC uses a bi-directional stepper motor (hence the 3 control pins) to control the amount of air passing through those two holes.
The filtered hole of the IAC is the Inlet. (Fed from the side elliptical hole in the throttle body via a cavity in the inlet manifold)
The other hole of the IAC is the Outlet. (Feeds to plenum chamber)
Old Oct 17, 2005 | 08:04 PM
whats the plenum chamber is it just the inside of the mani
Old Oct 18, 2005 | 03:47 AM
jmcclell's Avatar
Default Re: how does the VIAC works ? (ninjaskillz)
Yep, that's right
P. Hunter
Apr 7, 2013 05:46 AM
kev92ex4door
Jul 31, 2008 12:27 PM
8_6 luder
Jun 1, 2008 07:23 PM
royalfelix
Dec 10, 2007 11:43 AM
EKHWhat
Feb 19, 2007 05:24 PM
