Suspension & Brakes Theory, alignment, spring rates....
cheap five lug?
Old Oct 12, 2005 | 11:35 PM
ThefirstPACT's Avatar
Default cheap five lug?
Ok has anyone EVER measured the bearing on a five lug hub and a four lug hub? Could you just press in the hub to the bearing? And you can use an NSX caliper and 5 lug rotor?
If you dont know what i mean i can explain it more but...
Old Oct 13, 2005 | 05:08 PM
Default Re: cheap five lug? (ThefirstPACT)
anyone??
Old Oct 13, 2005 | 08:28 PM
hayabusa160's Avatar
the gsr and type r wheel bearing is the same. im going to transfer my 5 lug hub to my gsr knucle because i got in an accident
Old Oct 13, 2005 | 08:43 PM
raffiT78's Avatar
Default Re: cheap five lug? (hayabusa160)
good question, my problem i think is, im assuming the hub will work, but how about the caliper and the piece that hooks up to the caliper? where the pads sit. Would you have to use type r ones for that too?
Old Oct 13, 2005 | 09:20 PM
Default Re: cheap five lug? (raffiT78)
well hell...thats alot cheaper than getting a tradional five lug used! And all your stuff will be all NEW stuff and less than a used five lug setup!
So if i get integra suspension for my ek i could press in usdm type r hubs?
Old Oct 13, 2005 | 09:52 PM
in theory yes. i will be doing mines next week hopefully i'll let u kno how it goes
Old Oct 13, 2005 | 10:52 PM
yeah keep me updated! Really interested!
Old Oct 14, 2005 | 01:17 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
I know the brake rotors on an ITR/Prelude are slightly bigger than Integra rotors... I think ITR's are 11.2? and Integra is 10.8? This would cause issues with calipers and pads...
Old Oct 14, 2005 | 09:14 AM
Default Re: cheap five lug? (JDM_Ej)
If you do this you would need to run ITR calipers or nsx ones! This way i can at least save up and piece together a 5 lug! And plus i can have all new stuff under the car!
Old Oct 14, 2005 | 04:17 PM
itr is 11 inch gsr is 10.3. you have to use itr calipers or nsx one to make this work here
Old Oct 17, 2005 | 12:56 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">itr is 11 inch gsr is 10.3. you have to use itr calipers or nsx one to make this work here </TD></TR></TABLE>
I was close. But, the ITR/NSX Caliper won't bolt to an integra knuckle will it? You need to do some modification..
Old Oct 17, 2005 | 05:04 PM
PogKai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
I was close. But, the ITR/NSX Caliper won't bolt to an integra knuckle will it? You need to do some modification..</TD></TR></TABLE>
Yeah.. I was thinking about that too.. I want to do my gsr to a five lug.. I already have NSX calipers..
denraweb
Nov 29, 2008 07:01 AM
God-Driven
Jun 11, 2008 06:02 PM
Nova_Dust
Jan 17, 2005 06:36 AM
mstewar
Nov 6, 2003 06:46 AM
Fooser
Feb 17, 2002 02:44 PM
