Question about rear disc conversion on 97 civic coupe
i was wondering if it was necessary to get new trailing arms to convert your rear drum to disc. Because i was looking at the hub assembly in the back when i changed my brake shoes and it looks pretty much the same as the disc brake hub assembly. Is there not a way that i could remove all the drum hardware and replace it with the bracket for the caliper?
be professional
Re: Question about rear disc conversion on 97 civic coupe (PhatBoy5015)
The trailing arms are the same. The difference is the hub assembly. You can bolt disc brake hub assemblies onto your stock trailing arms. You'll need the proper Torx bit though.
boostitalready
11-25-2012 04:36 PM
terror_storm
117
03-20-2012 07:46 PM
d-series guy
10
01-01-2009 08:01 AM
vtec-adykt
01-27-2005 07:13 PM
MugenHonda
06-12-2003 05:14 PM
