92 Integra LS JDM B16 Code 20 + 23
Old Oct 12, 2005 | 07:06 PM
80mcfukdtp's Avatar
Default 92 Integra LS JDM B16 Code 20 + 23
There are quite a few threads about ELD and other nonsensical codes, but I'm still stumped.
This particular car had a B16 motor swap about 2 years ago, and ran fine (no codes) right up until it spun a rod bearing and was subsequently rebuilt. It has one of the cleanest wiring jobs I've ever seen, all solder and heatshrink where connections are necessary.
After reinstalling the motor, problems began. At first it threw a code 20 (ELD) and 22 (VTEC oil pressure). We checked everything over and shrugged our shoulders. We tried another known good JDM PR3 today and now it throws a code 20 (ELD again) and code 23. (knock sensor this time)
The car runs and drives nicely, but we don't want to deliver the car until all the codes go away.
Which sorts of situations will cause a code 20? (especially since this car doesn't even have an electrical load detector)
Thanks in advance for any input.
Old Oct 18, 2005 | 07:27 PM
80mcfukdtp's Avatar
Default Re: 92 Integra LS JDM B16 Code 20 + 23 (80mcfukdtp)
just one bump, since I'm on page 17 or something by now.....
Old Oct 18, 2005 | 10:06 PM
ProJectCvic's Avatar
I have a code 20 in both my hatchs. One was caused by a bad alternator...the other one, I have no clue. Good luck, subscribed
Old Oct 18, 2005 | 10:09 PM
Default Re: 92 Integra LS JDM B16 Code 20 + 23 (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">I have a code 20 in both my hatchs. One was caused by a bad alternator...the other one, I have no clue. Good luck, subscribed </TD></TR></TABLE>
BTW b/c of the code 20, both of my hatch speedo is not working.
Old Nov 12, 2005 | 01:37 PM
88cerx's Avatar
DID YOU GET THAT CODE 23 AWAY
Old Dec 19, 2011 | 06:50 PM
91 Ac's Avatar
Car won't start due to code 20,anyone please help. Read this and that but no direct answer, and electrical parts aint cheap once you buying their yours there's no refund nor exchanges. Had some idle problems after some after market parts then code 20 showed up, it's been 2 months now and still have no clue what it could be. Someone please help thank you.
Old Dec 19, 2011 | 07:01 PM
91 Ac's Avatar
Default 94 Ls code 20 problems
Wont start after getting code 20, had idle problem prior then got the monster. Keep reading this n that but no direct answer n like I said electrical parts once u buy'em their yours. Can someone please help, it's been two months and no luck
Old Dec 20, 2011 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
Might help to list your setup (year, make, model, engine, ecu, mods, etc)
Old Dec 20, 2011 | 04:19 PM
mark@silbernage's Avatar
You can usually pull the alternator and take it to the auto parts store for testing - to avoid paying when you don't need to.
ESPTUNING
Mar 28, 2005 07:24 AM
XzzYzzX
Sep 29, 2004 01:01 AM
itr crx
May 20, 2004 07:51 AM
