last minute flywheel
Ok i got a junked automatic 96' integra LS and im puttin it in my 92 hatch. my current dilema is this...
ive ripped it all down and bought flywheel, clutch and manual trans. i got to the flywheel today on the LS and saw that there is 8 bolts which i knew and they all have an AT on them im wonderin if this means those bolts are only used on the auto trans or can i use them to bolt on the flywheel for the manual trans? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">They're specific to the automatic and you'll need some bolts from a manual. ARP makes some flywheel bolts as well.</TD></TR></TABLE>
just order ARP bolts from summit! its better! or unless you go to a junk yard!
i am pretty sure they will...i've always had mixed nuts and bolts from both d and b and just used whatever i had...i'm positive that they should...unless i'm wrong...anyone else want to chime in on this...
btw: if you have it out already why not just give it a try...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawjboi »</TD></TR><TR><TD CLASS="quote">
btw: if you have it out already why not just give it a try...</TD></TR></TABLE>
JUST DO IT!
JUST DO IT!
well if you have time tomorrow wont you just goo to a junk yard and buy some use bolts off a integra motor... and pooof.. u dont have to worry about nothing... just my .02cent!
Why take the chance that what you have won't work, or spend extra time trying to throw together some sort of frankenstein solution? $30 should buy all 8 bolts brand new from a dealer, and I would venture that ARP bolts are probably cheaper.
Do it once, do it right!
yeah I would get those too. The flywheel bolts and the pressure plate bolts are both supposed to have those 12-pt heads (instead of standard 6-sided heads, you use a 12-pt socket to install and remove them).
