Seat sliding rail jammed!
Old Oct 12, 2005 | 03:54 PM
MasterCrx's Avatar
Default Seat sliding rail jammed!
I have a quarter that is jamming the sliding rail on my passenger side seat...its a 97 accord and I am wondering how I could go about getting it out....I have tried everything I can think of...I tried prying it out with a long screwdriver and it just jammed it more...so now the seat only can slide about 3 inches....I dont really want to remove my seats...I dont know how much work that would take....any comments or ideas would be greatly appreciated!
Old Oct 12, 2005 | 04:42 PM
Chiovnidca's Avatar
Default Re: Seat sliding rail jammed! (MasterCrx)
It's stuck over a hole in the seat track right? Put a screwdriver on it from the top and beat it through with a hammer.
Old Oct 12, 2005 | 05:27 PM
HondaTechPro's Avatar
Default Re: Seat sliding rail jammed! (Chiovnidca)
Unfortunately there is no procedure for removing a foreign objects from a seat track. Usually when this happens with a customer car I try for a couple minutes to work it out with a pick or a screwdriver, but if I don't have any luck I take the seat out. It is really easy it get out.... there are just 4 bolts that hold it in, one at each corner... on the end of the seat tracks. Take the seat out and you will have better access to the seat track.
Old Oct 12, 2005 | 10:22 PM
deserthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">It's stuck over a hole in the seat track right? Put a screwdriver on it from the top and beat it through with a hammer.</TD></TR></TABLE>
that's how i have done it numerous times ,,,dont rock the seat back and forth try to unjam it or it will jam it even worse than u will have to pull the seat out
Old Oct 13, 2005 | 02:07 PM
i_kick_turtles's Avatar
The same thing happened to me. I ended up having to take the seat out. It really isn't that much work.
Outrun
May 7, 2016 10:10 AM
R_Pizz3l
Jan 11, 2012 06:06 PM
liam821
Jul 17, 2010 08:52 AM
skinnyminnie1016
Feb 22, 2005 03:47 PM
diluted
Jul 22, 2004 01:39 PM
